Junior Member
swicthed from 3spd to th700r
switched for 3spd trans to 700r auto od trans...will the factory auto th350 or th400 linkage work or will i have to get some after maket type linkage
Re: swicthed from 3spd to th700r
69 swb stepside, rebuild and upgrade in progress |
![]() ![]() Join Date: Jan 2005
I have the stock TH350 linkage on mine and it works just fine. I can just barely shift into 1st gear.
![]() Join Date: Mar 2001
The stock linkage will work fine....but as pjmoreland stated, might have some trouble getting it in 1st, a little grinding on the column can correct this.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
![]() Join Date: Dec 1999
Stock works, but using the Lokar I think you can adjust it so the indicator for the R4 on the column will line up properly. Have one but haven't installed it yet.
Smitty '71 Short Fleetside Spring Valley, Ca. |
Do you recall the number of that lokar shift linkage? Was it a ACA-1800? I am curious if this would be the same for the 4x4 trucks as well?
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
