Old 12-10-2005, 06:56 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Scored some parts, have questions...
First question, are these correct 71 big block motor mount stands?
Second, the bracket on the throttle cable with the gm #, is that anything unusual? Or any bracket for a 71?
Third, what is the upper bracket on the accelerator? I know the lower is a th400 kickdown, but don't recall seeing the upper part before. Nothing was connected to it either.
Last, anything else i should look for on the truck before it gets squished? It is a 71 custom/30 deluxe. 133" dually. Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-10-2005, 07:07 PM   #2
Swbman
Re: Scored some parts, have questions...
Looks like all the stuff you have is from a 1971 bbc 396 or 402 truck, the towers look to be bbc kinda hard to tell from the picture angle, the accelerator cable bracket is definitely from a bbc my bbc suburban and bbc 68 chevelle ss both have them, I know from a fact the acelerator pedal bracket is from a bbc truck backed up by a turbo 400 tranny in fact for some strange I have found them also on factory bbc installed trucks.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 12-10-2005, 08:19 PM   #3
Bob Moore
If it is a 71 1ton dually, the front hubs should have adaptors on them to fit the dually style wheel and also be disc brake as well. Those parts are somewhat hard to find.
The carb bracket looks like a quad-jet item both BBC and SBC.
The in cab accel bracket is also BBC and SBC with T400 switch attached. The ear that sticks out is where the Hand Throttle cable attaches when so optioned.
I don't know if they started the larger diameter sway bar before 73 or not. You might look at the size.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-10-2005, 09:36 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
71-72 rear brake drums are a 2 year only item. Doubtfull if they are any good, but you never know.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-10-2005, 09:56 PM   #5
Rod
Yah the engine brackets look 68-71 BB to me.
Might as well go grab the heat shield off the cab for the BB exhaust on pass side.
Rear drums are hard to find...I still try to find any that are any good within the tolerances.
Any fender emblems?
Rod is offline   Reply With Quote
Old 12-10-2005, 11:17 PM   #6
too much stuff
Roadtrip!
I did look at the swaybar and it looked like my 1/2 ton ones. How much work is it to get the rear drums off? I know what it takes on a 1/2 ton, but i don't play on the heavy duty much. It still has 4 dually wheels on it. I don't think the truck has a ton of miles, but it has been sitting for awhile. The fender emblem is custom/30
deluxe
It had 8-400 emblems on the fenders, and 396 listed in the glovebox. If any one close enough needs the running gear, i could buy the truck and hold it for abit. I think it will be reasonable. (i think a couple hundred would buy whats left)
And rod, i already got the heat shield, the tranny hi-hump with no holes and the power steering res.
Thanks for all the input.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 12-11-2005, 12:48 AM   #7
teeitup
Just like to part out trucks!!
teeitup's Avatar
Was it cold when you took all these parts off???? Nice find Eric!!!
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 12-11-2005, 01:21 PM   #8
too much stuff
Roadtrip!
Randy, wasn't bad. We got to about 20 degrees, but the wind was brutal...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 12-11-2005, 01:58 PM   #9
truckdude239
truckdude239's Avatar
thje drums on an dully u have to remove the rear axles wheel bearings and everything else
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-11-2005, 02:00 PM   #10
truckdude239
if it to much trouble just grap the whole rearend
David fuller
2000 Tahoe 5.3l 378
Old 12-12-2005, 01:13 AM   #11
too much stuff
Roadtrip!
It would be easier to grab the whole truck if someone close enough could use it...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
