Old 12-11-2005, 07:53 PM   #1
shelby987
shelby987's Avatar
good tow strap manufacturer???
I am trying to buy a christmas gift, and I have been told that a 3" tow strap is the gift I need to find, specifically a strap with the fabric loops, not hooks.....I am new to the 4x4 crew, can anyone point me in the right direction? Also, what length am I looking for here....I have seen upto 30' in my search, is this overkill or is it something that will be good for regular use? The person looking for this will likely use it for farm use, and to pull friends/family out of ditches when the weather requires it....it will not be used for off road recovery.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 12-11-2005, 08:48 PM   #2
1967k30
1967k30's Avatar
Re: good tow strap manufacturer???
Pro Comp has some nice straps.That is what I will probably get for my wheelin' rig. We use a 2" tow rope for farm and ranch use.It holds up good and has some stretch to it which really helps.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 12-12-2005, 01:08 AM   #3
'71c204x4454
'71k204x4454
This sight has some nice straps. http://stores.ebay.com/Best-Bargainz The blue used ones. They are a good size also. I have 2 of them. They have them all the time so don't pay to much.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 12-12-2005, 06:49 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
http://www.recoverygear.com/default.htm
and
http://www.masterpull.com/index.cfm
I guess you'll need to decide if you want a "tow" strap or "snatch" strap, one stretches the other doesn't.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-12-2005, 06:52 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'd also recommend getting 2 different lengths, a 30' and maybe something around 10'. I did have a 100' piece of mouring line about 3" in diameter, damn thing was heavy, and a PITA to get knots out of! The one time I went to use it, it was still 20' too short.
Old 12-12-2005, 10:55 AM   #6
Mudder
Mudder's Avatar
For sure get the ones with the loops in the ends and get a couple of clevis for attaching them to the vehicle.
Mudder is offline   Reply With Quote
Old 12-12-2005, 03:53 PM   #7
shelby987
shelby987's Avatar
ok, apparently the person in question has been referring to the tow strap as a "snatch'em strap"....I have come across this brand in my searches, is it any good?
Is this a general term for a tow strap, or is he likely refering to this particular brand name?
If so, would there be any local stores or online stores where I should look to find this particular strap?
Old 12-12-2005, 07:13 PM   #8
Mudder
Mudder's Avatar
You can get them about any parts stores and even some farm implement stores. Most ppl call them tow straps but that si what they are talking about. Nylon stretches giving you a rubber band effect. You can jerk em hard and it doesnt break things like chains do. For serious stucks I woul get at least a 3"x30' strap. For just towing a 2" would probably work and it doesnt have to be no more than 20'.
Old 12-12-2005, 10:57 PM   #9
Rod
You should just check out a construction company around you and see where they get there slings from. You seem to be asking for an eye to eye nylon sling or twisted eye might be better for your purpose. Most crane companies and rigging companies can supply the good stuff, but your better off getting from the manufacturer..most slings are required to have the weight ratings and manufacturer on the strap its self if used commercially / industrially ....so you can see who made it if you go see one, and know what its capacities are in different lift or pulling configurations.
Here's a local manufacturer near me. http://www.saturnind.com/slings.php
Custom stuff is available also.
But you probably have something closer and might not know where to start looking.
Anyway there's a manaufacturer who does this kind of thing....not my company...just info.
Most of the industrial stuff is pricey due to liability issues...you might be better off finding a surplus or implement store as Mudder67 replied.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-12-2005, 11:52 PM   #10
Mudder
Mudder's Avatar
Ok the name fo the straps everyone around here use are Keepers. I couldn't think of the name. here's a place that has all kinds of recovery items.
http://www.recoverygear.com/DEFAULT1.HTM
Here's another from Desert Rat
http://desertrat.com/tow_straps/tow_straps.htm
Most of the places like Summit and Jegs have them also.
Old 12-13-2005, 01:03 PM   #11
shelby987
shelby987's Avatar
Keeper brand, any good? I am stuck between these and the recovery gear usa.....the keeper is rated to 33,000lbs for the 3' x 30', so I like that, but can't seem to find anyone who can tell me anything about them. I found them on an army surplus page....just wanted to make sure it was legit.
Old 12-13-2005, 01:37 PM   #12
Mudder
Mudder's Avatar
I have used them and have had no problems with them at all. They are probably as good as any. One thing to remember when using one of these is to not let it wrap or be against a sharp object when towing as it will cut the strap.
Old 12-13-2005, 05:49 PM   #13
MJN
MJN's Avatar
AAA Sling (downstate Michigan) has always been a good company to deal with. Our Four Wheeling club here at school. www.mtu4x4.org has bought straps from them for years. They're Powerflex straps are stretchy and hold up to all kinds of abuse. I use their 4"x30' and 6"x30' for wheeling that I do. We usually do a club order and they've always been a lot cheaper and tons better quality than a parts store or hardware store straps. Here is a picture of my 6 inch coiled up. IIRC, it has a 60,000 lb rating. http://www.mtu4x4.org/gallery2/v/mem..._1080.JPG.html Sorry for the quality, not a real good picture.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
