Old 12-11-2005, 11:40 PM   #1
bartstoy
bartstoy's Avatar
Noise from motor on radio
Finally sprung for a new radio for my '69 chev truck. Got a Custom Sound that fits in the dash very nicely. Problem I am having is motor noise when the motor is running. Changed the ground, insulated the fender washers next to the dash, rerouted the power lines. Uninstalled and hooked up radio on floor of cab, still get motor noise. Methinks the antennae might be the culprit but don't know what to do about it. Can anyone give me some hints. Radio I replaced didn't have the problem, but it didn't really fit the dash either.
Original owner '69 C20, long, fleet.
454 BB with Edelbrock stuff.
Work truck for years, 2nd restoration going on.
'69 C20
'03 Tahoe Z71
70 Hp Johnson pushing aluminum bass boat.
All things in life are uncertain, so eat dessert first.
bartstoy is offline   Reply With Quote
Old 12-11-2005, 11:58 PM   #2
jhow66
jhow66's Avatar
Re: Noise from motor on radio
Still got point ing. If so is there a condersor on the side of your coil.( it is there to filter out ing. noise (inside cap on HEI). Every which one you have is bad.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-12-2005, 12:18 AM   #3
HelpDeskGuy
You can also go to any hi-fi stereo shop and they will have an external inline filter pretty cheap.
HelpDeskGuy is offline   Reply With Quote
Old 12-12-2005, 02:20 AM   #4
Scottb
resistor plugs or shielded core spark plug wires could stop it too- but the easiest is the 10 dollar inline noise filter from walmart for the stereo.
70 GMC C2500 BB 402, LSD Dana 60 rear, Converted to SM 465, Holley 750, Edelbrock Performer RPM air-gap intake, Flowtech Headers, 2.5" Flomaster Exhaust, HEI ignition, 81 Chevy disk Brakes.
All work done by myself. last 1/4 mile (almost 3 years ago) 15.9 @ 86
Scottb is offline   Reply With Quote
Old 12-12-2005, 02:28 AM   #5
bartstoy
bartstoy's Avatar
Thanks to all, going to find an in line filter somewhere and give that a try. I forgot to mention I just installed new resistor plugs, but the noise was still there.
'69 C20
'03 Tahoe Z71
Old 12-12-2005, 05:10 AM   #6
86SILVERADO
86SILVERADO's Avatar
It was a long time ago that I fixed this problem but I remember it had something to do with multiple grounds coming from the stereo deck itself if you do some searching online you should find the solution. I even
did the whole noise filter thing and it didn't do jack. It was something like removing the braided strap from the deck or keeping that one and not using the black ground wire if that makes any sense. search under car stereo noise and multiple grounds or redundant grounds or something like that.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
