Old 07-12-2002, 11:33 PM   #1
photoglg
photoglg's Avatar
Control arm bushings, Help
Does anybody have a trick to remove the bushings from the control arm, the manual calls out alot of special tools, could I just use a bolt in the sleeve and pound it out?
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 07-13-2002, 02:43 AM   #2
DHregdovic
I just did mine about 2 months ago. I replaced all the steering linkage, ball joints and control arm bushings. The bushings actually come out fairly easy with a 3/4" socket set. I bought a cheap set from Harbor Freight Tools for $35.00. The actual bushings look like a very large nut on the end of the control arm shaft - there will also be grease fittings on them unless they've been broken off. I also recomend you replace the rubber grease seals that are on the inside of the bushings. I bought some aftermarket seals/bushings. Bushings were fine but the seals were not made the same and in turn didn't work. For about $12.00 you can still get new ones from your local Chevy dealer that will work great (BTW: they discontinued the original grease seal part number but the alternate part number will work great... They will know what you're talking about).
If you have anymore questions, let me know and I'll see what I can do....
67 LWB GMC
250 inline w/4spd manual
Disc/power brake conversion
DHregdovic is offline   Reply With Quote
Old 07-13-2002, 03:55 AM   #3
big.l.a
big.l.a's Avatar
Bushing replacement
Go Autozone (Loan-a-tool)and get a Crow's Foot If you don't already have one. they pop right out.
71 C10 LWB With
Edelbrock 7101& 1406 Carb
Accel HEI Blue Print
Accel 8.8 Wires
Soon to have possi &
186 Camel hump heads
Dropped 2-1/2F&4R
Dynomax Headers
Duals Flowtech Aftburners
Tonneau Cover Frm 89 F150
79 Monte C
big.l.a is offline   Reply With Quote
