Old 12-12-2005, 12:25 AM   #1
skokie
skokie's Avatar
Clean way to change intake manifold
I am going to be swapping out my intake manifold and I need to know if anyone knows of a way to remove the intake without getting coolant everywhere. Is it best to drain the radiator? Or is there a way I can get just the coolant from the intake only?
Thanks Much..
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-12-2005, 12:31 AM   #2
muddpile
muddpile's Avatar
Re: Clean way to change intake manifold
Any time I do it, I drain the coolant out of the rad through the petcock on the bottom. A bit of coolant still gets spilled in the oil, but not so much that way. An oil change after an intake swap is always a good idea.
muddpile is offline   Reply With Quote
Old 12-12-2005, 12:32 AM   #3
skokie
skokie's Avatar
When you drain the radiator how much coolant do you have left in the intake when you pull it?
68 build thread
Old 12-12-2005, 12:45 AM   #4
screamin_c102
screamin_c102's Avatar
Shop vac in the thermostat housing....works like a charm
Also works great for getting the gasket scrapings out of the ports and valley.
As ststed above, an oil change is a definate afterwards.
screamin_c102 is offline   Reply With Quote
Old 12-12-2005, 12:51 AM   #5
skokie
skokie's Avatar
I like the shop vac in the thermostat housing idea. Never even thought of it. So will drain radiator, remove the top radiator house and insert shop vac
Thanks guys. I appreacite it..
68 build thread
Old 12-12-2005, 12:53 AM   #6
71swb4x4
71swb4x4's Avatar
If you have a thermostat, and the engine is cool, you won't get much coolant out of there. You could vacuum what's in the housing, and then pull the housing and thermostat, put the housing back on and vacuum the rest out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-12-2005, 01:28 AM   #7
steves1967
steves1967's Avatar
I like to pull the 1/4" plugs on the side of the block and drain the fluid there, usually gets it all out of the block and rarely do I spill any into the engine, although i always change oil afterward...
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 12-12-2005, 02:16 AM   #8
screamin_c102
Actually, the thermostat doesn't stop the flow of coolant it signifiganlty restricts it. The Shop Vac pulls enough coolant past the 'stat to empty the intake and lower the level in the heads as not to spill into the valley. I usually shove it into the upper radiator hose and leave it run for a few, use a clamp if necessary, while I am working on pullin the carb or gettin' tools ready.
I thought the old timer that showed me the trick was too.
Old 12-12-2005, 02:59 AM   #9
skokie
skokie's Avatar
I opened the drain plug on the radiator and let it go right into the bucket. Not to bad. I popped the thermostat housing off and there is not that much in there. I had to call it quits for the night but I will be doing the shop vac thing tomorrow night to get the rest out.
68 build thread
