Old 12-12-2005, 05:44 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
off topic... sorta
I wasent quite sure where to put this.. anyway, I have a porblem with my 93 honda accord SE making a clunking noise when going over bumps and making a left turn. the machanic said *after looking at* it was the sway bar end links were broken or was it the bushings, anyway how hard would it be to replace them? never done it befor. I figured sence I would be praticly taking the thing off I might as well replace all the sway bar bushings. can someone recomend me to some good ones? looking to something other then rubber. would I need to torque it down? * I dont have a torque wrench* anyway hopefuly ya'll can help me, thanks matt
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 12-12-2005, 09:48 PM   #2
nwmod39
nwmod39's Avatar
Re: off topic... sorta
im not sure as to how much you would like to spend on this project but here is a full front and rear performance sway bar kit with all the components needed to do the install.
http://www.jegs.com/webapp/wcs/store...0957&langId=-1
nwmod39 is offline   Reply With Quote
Old 12-12-2005, 10:07 PM   #3
79gmcc15
79gmcc15's Avatar
I wasent planing on upgrading anything other then the bushings. but thank you will keep that in mind though!
RIP ELJAY
Old 12-12-2005, 10:26 PM   #4
powell72
powell72's Avatar
That is fairly common on Hondas, usually the bolt breaks. CarQuest has a good replacement kit that has everything you need. You'll need two. They are easy to replace. You don't need to torque them.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 12-12-2005, 10:34 PM   #5
79gmcc15
79gmcc15's Avatar
I read a generic instructions about how to do it and it said that you lower the car down then tighten the end links. I was wondering, do I have to do that? because theres No way I can fit under that thing to tighten it lol. thanks again!
RIP ELJAY
Old 12-12-2005, 10:40 PM   #6
powell72
powell72's Avatar
When I do them at work I'm under them while their on the hoist with the suspension hanging. I don't think it's an issue to tighten them with the suspension unloaded.
Chris
Old 12-12-2005, 11:03 PM   #7
79gmcc15
79gmcc15's Avatar
cool good to know! thank you
RIP ELJAY
Old 12-12-2005, 11:23 PM   #8
71swb4x4
71swb4x4's Avatar
I had a civic that they broke on. Pretty easy to replace. You do want to have a load on it when you tighten them. I had mine jacked up, got it all hooked up, then I lowered the front wheels onto some ramps. The ramps are like the ones you can drive on to change oil. That put a load on the suspension and I could still reach under and tighten them.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
