Gas-gunk mystery solved
Hey all, thought Id share the solution to my little gas problem. My truck started running real rough and I tried everything I knew how to do (tune up stuff mostly). Finally gave it up and took it in to have it fixed. They rebuilt my carb and it ran great! After another tank of gas it started running like crap again so I took it back. Carb all gunked up again. Turns out I had stuff in my tank. So, I got a new in-cab tank from brothers (fit perfectly by the way) and replaced it and took a good look in the old one. The old one had a brown layer inside that was breaking down and making it through by new fuel filter (very fine stuff)
Turns out about 10 years ago I had the tank dipped and sealed, now the sealer is breaking down and gumming up the works. Thought I would pass this along in case there are other guys out there using a tank that has been sealed. Also, I have read of acetone being added into gas by the stations and by vehicle owners. While that is all fine, it will disolve any tank liner. I think that is what heppend to me. I believe the station down the street is adding acetone. Anyway, I should finally have my truck back this week! ![]()
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
laying low
![]() Join Date: Mar 2001
Re: Gas-gunk mystery solved
Well dang. I know you are relieved to find out the cause of your probs. Happy motoring.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 12-12-2005 at 08:45 PM. |
What sealer did you use Kreem? have seen many horror stories with that stuff and it is solvent based. The product I use will barely come off with dynamite. Coated my first tank 1982 and still looks good.
#4 | |
What's the purpose of acetone in gasoline anyway?
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
#6 | |
'67 K10 Work In Process
It also helps MPG most of the time, but I doubt that they would add it for that reason
