Junior Member
Golf balls inside of tires.
Has anyone heard of putting two golf balls inside of a tires to balance the tire instead of wheel weights? A trusty inmate said that he put two golf balls inside his large mud tires and as the tire rolled the balls would stay in the place needed to balance the tire.
1972 GMC K2500, stepside, stock 350, 4 speed. Former F/D truck with 32,000 miles, no rust. 1973 Jeep CJ 5, 304, 33's with side pipes 2008 GMC 2500HD, CC, SWB, D/A, SLT |
![]() Join Date: Sep 2005
Re: Golf balls inside of tires.
ummm not ture i work in an tire shop the golf balls will move inside the tires even infalted they will move now i have heard of using sticky bbs to0 help balnce out tires but never tried it
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Never heard of it, it probably doesn't work. Wheel weights are easy to get a hold of and getting tires balanced shouldn't be a problem.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
collector of vintage rust
As the wheel accelerated, the balls would move farthest away from the wheel. what would make them go the same spot every time to help balance anything?....I dont think its feasible.
BlahBlahBlah
when we were kids we would take a couple of marbles that would fit in the lip of our frisbees. you could roll em around the lip and they wouldnt fall out. when we tossed the frisbee that thing would wobble through the air with the marbles centrifically held in the lip...yes we were easily amused...it seems to me the golf balls would do the same thing except on a larger scale...but i didnt do well in physics so i could be all wet...=)
![]() Join Date: Aug 2005
Trusted inmate? Is that an oxymoron? As a prison RN, I would advise you to find a better source of information
![]() Last edited by SOON2BLAZE; 12-12-2005 at 11:22 PM. |
User #12137
![]() Join Date: Apr 2004
i think the golf balls would eat the inside or the tire in time and kill the tire
just my 02 cents worth |
use equal- golf balls dont work well. go to a truck stop shop and they wont charge u much- good for lifetime of tire- makes em last way longer
70 GMC C2500 BB 402, LSD Dana 60 rear, Converted to SM 465, Holley 750, Edelbrock Performer RPM air-gap intake, Flowtech Headers, 2.5" Flomaster Exhaust, HEI ignition, 81 Chevy disk Brakes. All work done by myself. last 1/4 mile (almost 3 years ago) 15.9 @ 86 |
#9 | |
Uh... Yea...What soon2blaze says...
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
4x4 guys do it for larger super swamper tires. Over on Pirate4x4.com I read about it. airsoft plastic bb's and regular bb's do it too. People swear by it, but they only use them on large tires that won't balance with weights. I have airsoft in my 37 Irok's, guess it helps.
Aaron |
Custer had a plan too.
Low compression balls would spin and bite better, but high compression balls are better suited for distance driving. It really all depends on how your gonna use your truck.
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ![]() 05 Subaru Outback for mileage Last edited by avejoe; 12-13-2005 at 02:31 AM. |
My experience with golf balls is that I always wind up putting them into the water so if I put them inside my tires, my whole freakin truck would probably end up in a pond as well!! Think I'll pass but let us know how it works out!! (:>)
#13 |
Myth Buster's hasn't done this one yet to my knowledge.
#14 |
![]() Join Date: Oct 2001
Sounds like the old balance tubes they used to sell for semis. It was a plastic tube that mounted on the rim edge like a trim ring. It had a light oil in it and several steel ball bearings. The plan was that when rolling the steel balls would migrate to where the wheel needed them for balancing. I have no idea how well they worked. Since they were more $ than weights they never gained popularity.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
#15 |
Professional Grade
It is a very common practice with a big 4x4 to stick stuff into your tires to balance them. The problem with wheel weights is that if you hit anything, those weights come off almost immediately, and the tires are so big, that you need some pretty large weights to balance them anyways.
People don't use golf balls though. They break down inside of the tire, and at low speeds, make noise. Usually they use lead BBs, or plastic BBs. They will not make as much noise as golf balls, and distribute themselves better. And yes, they do work quite well ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#16 | |
Just need a couple more parts.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
#17 |
![]() Join Date: Feb 2001
Yes it works. The golf balls will come apart in time and they make noise when you come to a stop. The BB's have a tendency to rust. This is the way to go. Have heard nothing but good about this way.
http://www.innovativebalancing.com/gallery1.htm |
#18 |
Saving 1 truck at a time!
Well here is the response from Firestone/Bridgestone about this practice.
http://www.trucktires.com/publicatio...v6iss2/ra9.asp
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 12-13-2005 at 03:16 PM. |
#19 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
My friend that runs a Tire store uses this product or something simular: http://www.counteractbalancing.com/
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#20 | |
Old Skool Club
![]() Join Date: Jun 2001
I don't see that having them inside your tires is of any possible benefit. I am thinking along the line of the "spinner" type of big roller wheels. They don't start out spinning, from a stop. There has to be some acceleration, during which time the spinner starts to spin. When you stop, the spinner keeps spinning until there is no more momentum. I foresee that the golf balls, bb's or any other round object would do essentially the same. I'm not an physics person, either. I just have to go by my gut, which I am amply qualified to do.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#21 |
#22 |
I like Top-Flite myself
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! ![]() 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
#23 |
I ve got some swampland in Florida I d like to sell you. Let me know if you re interested........
#24 | |
Wrong forum Jim ![]() JKR
****Have you ever danced with the devil in the pale moonlight....I ask that of all my prey**** 68' C10 Short Step (rebuilding as we speak) 72' Custom Camper (wrecked, parting out) 79' C10 Fleet (rough, parting out) 97' C1500 Short Step Custom (DD) 97' Kawaski VN800a Customized 99' Z71 Silverado 04' Suzuki Volusia |
#25 | |
Professional Grade
There is a possiblity I may be picking a K-5 up, but I dunno when I'd be getting tires for it, if I did.
