Old 12-13-2005, 11:11 AM   #1
76bonanza
76bonanza's Avatar
opinons on electric fans
First one 16 inch or two 12's Which do you prefer and why?
Second wired directly to come on and off with key or hooked up to a thermostat?
Thanks trying to decide what type of setup to run.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-13-2005, 11:18 AM   #2
fade94
fade94's Avatar
Re: opinons on electric fans
Mine came with dual electrics on an adjustable thermostat and an switch to turn them on manually. They work great. I don't know the size off the top of my head.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 12-13-2005, 11:57 AM   #3
Putter
More Cowbell....
Putter's Avatar
I have a pair of 11" fans on my truck hooked to a temp sensor. They only come on if I am sitting in traffic and the temp gets up around 190`. Then as I drive, they usually cut back off as the temp drops. So they are not pulling any voltage most of the time. I love'em.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 12-13-2005, 01:05 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I have a couple of duel 12" fan assemblies on my trucks. 1 on a big block and 1 on a small block. Both are 4X4s. I like 2 twelves because if one fails you have the other to get you home. I also think they look cool!! I have them hooked up to a thermostat that reads the temprature of the radiator. Whay have them running full time using up electricity? No need. My kit also comes with a manual override switch in case of thermostat failure or if you need to run them with A/C. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-13-2005, 01:09 PM   #5
Andy4639
Old member
Andy4639's Avatar
I put a small 12" jap car fan on mine. I have the factory fan, but placed this one in front of the radator to come on with the AC, just for summer time use. I don't really need it but I had it so I used it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-13-2005, 01:45 PM   #6
76bonanza
76bonanza's Avatar
Wes I like your kit does is come with everything including thermo and wiring? Also how hard would it be to wire in an led light for the dash to light when fans come on? Also it is truly bolt on no fabing? can you tell me what flex-a-lit- fans you use? or what amp drawn they have? Thanks love your setup just not sure if I can part with that kind of cash yet. got any pics of your setup installed?
1968 c10
lowered 3" 4"
Old 12-13-2005, 02:36 PM   #7
Mudder
Mudder's Avatar
I have a single 16". It works great but would get doubles the next time. Just in case one would fail.
Mudder is offline   Reply With Quote
Old 12-13-2005, 03:04 PM   #8
crazy longhorn
Fabricate till you "puke"
I run a pair of 14" fans on my longhorn.....yes, they do fit tight! they are on a homeade shroud, & run Painless controls . the fans keep my 383 cool in the summer here in Illinois, & they really dont run much unless the truck is idling in traffic...... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-13-2005, 04:56 PM   #9
farside847
farside847's Avatar
I see alot of guys run two fans in case one fails. But looking at how they hook up wouldnt they both fail at the same time? Or do the fan motors themselves burn out?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 12-13-2005, 06:18 PM   #10
76bonanza
76bonanza's Avatar
only if the thermo switch failed if just the fan motor quits the other will still run. I would have to say that the fan motor would fail more often than the switch I would think. Anyone running wes's dual setup?
1968 c10
lowered 3" 4"
Old 12-13-2005, 06:33 PM   #11
mocwon
Keep On Truckin'
mocwon's Avatar
These work great (the twin one), fit nice and are easy to install, $238 from Summit, highly suggest the adjustable thermostat:
Flex-a-lite low-profile electric fans have the lowest profile available, yet flow up to 2,500 cfm. They have lightweight nylon shrouds with full-contact rubber seals, and some even offer several choices of shroud color. There's also an optional, adjustable thermostat and air conditioning relay, as well as a manual override switch to shut down the fan for mud racing or water crossings. A wiring diagram and installation instructions in English, Spanish, and French are included.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
