Old 12-13-2005, 12:44 PM   #1
shelby987
shelby987's Avatar
HO52 unit questions
I saw in the parts section a 71 Eaton ho52 rear axle with posi and 4.10 gears....would like to upgrade my truck to this setup...currenty open and 4.56, my question is this, can I just pull the center section and swap with mine? (4wd, need to upgrade front axle gears as well....so I already know that)
Also, is this actually rare? Is it worth the 6 hour drive, or can I come across this at most decent scrap yards that deal with older vehicles?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 12-13-2005, 03:40 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: HO52 unit questions
most all small block/automatic powered trucks should have the 4.10, it came standard in that eng/tranny configuration. Including my parts truck, I have had 4 trucks, 3 of them had eatons, and all 3 were 4.10 open. The limited slip is not very common at all in a 4.10.
Walking into any junk yard in this neck of the woods 9including your neck) you aren't likely to find one since they rusted to dust many years ago.
Old 12-13-2005, 06:46 PM   #3
1969 GMC
1969 GMC's Avatar
it's actually a detroit locker, not a limited slip. i'd say they are pretty rare, I have yet to stumble across one in the JY even though i've found a few eatons. i did buy one off of another board member, but thats a different story.
and yes, the third members will swap out just like a ford 9. just pull the shafts and unbolt the third. they are pretty heavy though, over 100 lbs, so have a friend or an engine hoist to help.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-14-2005, 12:36 AM   #4
72MARIO
72MARIO's Avatar
I have one of the "rare" Detroit Lockers here. Not sure what I am going to do with it. I know there hard to find just not sure how long I should hold onto it.
69 GMC covered the rest of your question very well.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-14-2005, 08:08 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's weird. In the last year, I've had a two 72's and a 68 with the Eaton rear. All three were the lockers. I thought they were all lockers until I read this
Old 12-14-2005, 10:50 AM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
And I've never seen a HO52 with a locker. Go figure.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 12-14-2005, 12:03 PM   #7
shelby987
shelby987's Avatar
trying to buy the one that was listed on ebay, whats the best way to get something that size shipped from IL to Michigan? How do I go about putting it on a grey hound?
Its just about 6 hours away....and in my truck gas = shipping.....and I just don't have the time right now to drive there anyway....as it is the 3rd member will likely sit in the garage for a couple of months.
Also, does the '3rd member' consist of the locker and the gears? What tools/knowledge will I need to drop this in place of my 4.56 open diff setup?
Old 12-14-2005, 12:48 PM   #8
1969 GMC
1969 GMC's Avatar
The 3rd is self contained, it has the gears, carrier, locker, bearings, and the yoke.
To remove it you simply unbolt the two axleshafts from the housing (make sure to have a catch pan under the ends because gear lube will spill out) and slide them about halfway out. Then you simply unbolt the 3rd, and it will come out. It might be rusted so it will take a little "talking to" with a sledge or big screwdriver. Other than that its very straightforward. Make sure to have a catch pan for the 3rd as well.
Then go back in reverse order. attach the 3rd and then slide the shafts back in, and bolt them on. i do not think gaskets are available from GM anymore, so use silicone or RTV, but don't use the whole tube. top off the diff with gear oil, and you're set.
the only tools you will need is a ratchet and sockets, I forget what sizes off the top of my head. then catch pans and some rags in case you spill any gear lube in your work area. then some sealant for the 3rd and axleshafts.
EDIT: they can be shipped FedEx. ChrisH on this board sent me one that way. He built a crate out of wood then slipped it inside a cardboard box to sneak it under their "no wood crates" requirement.
iirc, it weighed right around 150 lbs, but that was a 5.14 open diff, the No-Spin weighs a little more, so greyhound might be your best bet.
these also fit perfectly on top of 5-gallon buckets, so you may want to recommend that to the guy on ebay if he ships it to you. set it on the bucket then strap it down to a pallet.
one last thing, the No-Spin was an option in these, just like anything else. these axles all came stock with an open diff.
good luck!
1969 GMC K2500
1996 Honda Accord
Old 12-14-2005, 02:22 PM   #9
shelby987
shelby987's Avatar
ok, looks like the one on ebay was actually won by someone, when I checked with an hour to go, no one had bid on it....so if anyone out there has a 4.10 eaton 3rd member with a locker in it, that they are looking to sell....let me know....would also like the gears for an D44hd to match the front gears on my 4x4 as well.
Old 12-14-2005, 04:25 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Sure you have Fred - my 69 K20 has the factory No-Spin.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-14-2005, 09:34 PM   #11
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The No-Spin could have been added for no extra $$$ back then according to my 1970 10-30 series owner's manual. Kinda weird. The 4.10 HO52 rear in my truck has one, and the 4.56 HO72 rear I have has one too.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 12-14-2005, 10:49 PM   #12
Rod
Well my 70 dealer data book lists the no spin at $ 134.50 MFR suggested delivered retail price. List price was $125.
Also says not available when 400 engine ordered....I believe that was proved wrong when a glove box sticker recently posted the contrary.
By the contrary, I'm talking about 3/4 ton not having detroit lockers when BB were ordered...I know the one tons could..mine does and its factory BB.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-15-2005, 09:41 AM   #13
shelby987
shelby987's Avatar
well, I have a 3/4t with a 250 I6......I could be wrong, it might have a locker, but its definately NOT listed as one of the 4 options on the glovebox sticker, and yes, its original.....I know that in the winter, the traction does not feel like its locker driven, also I know that it has 4.56 gears, and a 10% reduction in highway RPM....while very small, would be nice.
Old 12-15-2005, 11:55 AM   #14
67'ShortMonster
We have a collection of old 67-72 trucks, about half the 3/4" tons have lockers. The old 70 3/4" burb came with 4.10 and locker. The 1 tons, both came 5.13 no lockers... the 70 292 4x4 came with 4.56 and locker, same with the 71 camper special.
Anyone looking to get locker for theirs, can swap some of the internals to 14 bolt stuff, lots of the 4x4 guys like the h0's. Because of the 3rd member ect. I have one in my YJ... 4.10, locker, with the 1 ton cab and chassis hubs to narrow it down to 'jeep width', then i put disk brakes on it.
67'ShortMonster is offline   Reply With Quote
Old 12-16-2005, 12:02 AM   #15
Rod
My suburban 70 GMC 3/4 4x4 six cylinder came with the detroit locker also.
Old 12-17-2005, 09:43 AM   #16
shelby987
shelby987's Avatar
ok, so maybe I am wrong???? Its definately not listed on my glovebox door as a locker, is it always listed, or could it be implied....because I have a similar setup to many of the trucks above (3/4, 4x4, 6cyl).....is there an easy way to tell? (very bald tires, maybe it just feels like the bad traction of a open diff because of that?)
its winter, will simply getting the truck on some ice and giving it some go juice tell me (with a spotter looking at both tires??).
Old 12-18-2005, 12:25 AM   #17
rwgregory
Just jack up one rear wheel w/the trans in neutral and the E-brake off and
see if that wheel will spin by hand. If the wheel spins freely, she no gotta
posi.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 12-18-2005, 12:58 AM   #18
Rod
Always been a listed option on the truck I have or from parts ones I've grabbed..option G86 No Spin rear axle.
Old 12-18-2005, 09:18 AM   #19
shelby987
shelby987's Avatar
ok, she no gotta posi....the wheel spin is how i figured out that I got 4.56 gears.....good.....or bad to know depending on how you look at it.
