12-13-2005, 04:26 PM | #1 |
LAIDOUT
Dropped lower control arms and airbags
I am wondering how close you could get the frame down combining drop spindles, drop arms and airbags? Added to my drop spindles and bags, I am thinking another 3" of arm drop would put my X-member close to the ground. Is there some component conflict I am not realizing?
12-13-2005, 06:38 PM | #2 |
www.73-87chevytrucks.com
Re: Dropped lower control arms and airbags
Yes, there is a conflict. You would be putting yourself at risk as those components are not designed to go together. By putting Lowered LCA's with dropped spindles, the lower control arm will be closer to the ground and if you get a flat, all the weight of the vehicle will be on the control arm and you will loose control.
A better/safer alternative is a dropped crossmember.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-13-2005, 09:35 PM | #3 |
where can you get the dropped cross member from?
-Steve |
12-13-2005, 09:38 PM | #4 |
Won't work.... As Capt said. Also you should be able to lay the control arms on the ground with just bags and spindles.FYI- Your crossmember sits lower then your frame rails.
12-13-2005, 11:09 PM | #5 |
This was a setup I had that had NO spindles and only my bag setup:
This is the limiting factor on getting the front of these trucks down. BTW, I make and sell dropped crossmembers. This is a write-up XXL did on the one I chopped for him. http://67-72chevytrucks.com/vboard/s...d.php?t=137398
12-13-2005, 11:38 PM | #6 |
A day should have 30 hours.
i am running 3'' drop spindles and air bags in the front of my truck (the spindles for the look, the bags for the ride quallity)
and i get so low i can set my front cross member on the ground but my tires hit the inner fender. |
12-14-2005, 01:49 AM | #7 | |
12-14-2005, 12:54 PM | #8 |
I have Bags/ART Strong Arms/ 2 1/2 dropped spindles. Front crossmember sits on the ground.
http://67-72chevytrucks.com/vboard/s...95#post1431695 CapN K -- How much for dropped crossmember? Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-14-2005, 12:54 PM | #9 | |
LAIDOUT
My truck with drop spindles and bags sits my LCAs about 2" from the tarmac, this with the 30" roll around wheel/tires currently on it. |
12-15-2005, 07:45 PM | #10 | |||
It will look like this when I am done: Here is the feedback I got from XXL (pics are in there also): http://67-72chevytrucks.com/vboard/s...1&page=1&pp=20 Quote:
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 12-15-2005 at 07:52 PM. Reason: forgot to answer BigSky71 question. |
12-15-2005, 08:55 PM | #11 |
BigSky & Layed, have you guys cut out your bump stops yet? That may be what everyone else did to get that low.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-16-2005, 12:31 AM | #12 |
Catkoas,
Can we still use stock motor mounts or do we need to cut them also ? It's is so Tempting to put my truck on bags....
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-16-2005, 01:04 PM | #13 | |
12-16-2005, 01:56 PM | #14 | |
LAIDOUT
12-16-2005, 03:18 PM | #15 | |
12-16-2005, 09:33 PM | #16 | |
same but i am running a 245/50/R15 in the front without the bottom bag and i touch ground |
