12-13-2005, 05:19 PM | #1 |
PROUD TO BE A MEMBER
Anyone know if
Does any one know if i can remove the door hinges on a 67 pickup without removing the the fender??? If so any tips ?
12-13-2005, 05:26 PM | #2 |
Sisyphus was my mentor!
Re: Anyone know if
I've done it & I almost had a brain hemorage. It is a very tight space & you'll need small a few wrenches at various angles to do it. Yes, it can be done, but next time I'll pull the fenders.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
12-13-2005, 06:19 PM | #3 |
Re: Anyone know if
Use an offset boxend and you should have no problem, just takes a little time. There is one problem, or should I say you will think there is, as you loosen the bolts the backing bracket may start to wiggle, I thought that it would drop off upon removal of the last bolt, it didn't, must be some type of holder inside. I did this when I rebuilt my hinges. My 2 cents, Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2. |
12-13-2005, 07:32 PM | #4 |
Designated A-hole!
Re: Anyone know if
Hey Steve, long time since we heard from you.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-13-2005, 08:04 PM | #5 |
Re: Anyone know if
Mark the location of the hinge on the door and then remove it from door then there is plenty of room to take it off the cab side, you can allso take a short pencil and mark the cab hinge side to get them to lign back up when re-installing.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
12-13-2005, 09:51 PM | #6 |
PROJECT 7DEUCE
Re: Anyone know if
I have done it with it on the truck but never agian its easier to just losen up the back part of the fender to gain a little elbow room inside..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
