12-13-2005, 07:58 PM | #1 |
identify this wire please
well i think i know it's purpose, but i don't understand this. ok the ac controls has 2 lights in it, both have gray wires. the 1 closest to the glovebox goes into a bundle with an orange wire, comes out near the fuse panel with a male connector, and a gray wire coming out of it, both plugging into an orange wire. that "other" gray wire has a female connector on it and i have no idea what to connect it to. i traced the other light's gray wire into the dash harness, and 2 gray wires go into the instrument cluster???
ok this is the wire in question, that female connector goes where? a shot right below that connector, the lower gray wire goes to the right light and the upper... here's the lights, the right one's wire is also the lower one in the above pic, and the right light's wire goes to the dash harness... continued left light going into harness instrument cluster... i see 2 gray wires leading to 2 of these pins. this seems like a wild goose chase, but i don't know where to find a male connector to plug into the female connector i have. any help would be appreciated. |
12-13-2005, 08:35 PM | #2 |
Re: identify this wire please
It may be the plug for the light on your a/c control. I think the a/c control has 2 bulbs. That's something I should know instead of guessing.
12-13-2005, 08:45 PM | #3 |
yeah there are 2 lights for the ac controls
12-13-2005, 09:06 PM | #4 |
C10 Club Tennessee
Hey Matt,
Not that I can fix my own wiring problems but here's a the diagram for both the 3 hole bezel and the 7 hole bezel. Maybe it will help.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
12-13-2005, 09:48 PM | #5 |
PROJECT 7DEUCE
Thanks for posting that harness pic I think I may have just soled my lighting problem..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-13-2005, 10:30 PM | #6 |
hmm, that did answer 1 question, how the light gets power, ok so now the lights should work, can't test em with burned bulbs, and no power anyways, but what is that connector for? if i don't get a good answer i'll just leave it dangling and see if it makes a difference this summer when i finish the build.
12-13-2005, 11:22 PM | #7 |
Matt - It is just another place to add power on that circuit. You could plug in your tilt column indicator lamp there or any other thing you wanted to dim when you dim the dash lights.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
12-14-2005, 12:06 AM | #8 |
indicator.. you mean like gear position up on the column? my truck has a floorshift now so maybe i could run a wire to the inside of that and light it up inside.
12-14-2005, 12:58 AM | #9 |
Yes
12-14-2005, 09:10 AM | #10 |
C10 Club Tennessee
Glad it helped-Hey French now you can come solve my problem
12-14-2005, 11:16 AM | #11 |
thanks guys!
12-14-2005, 11:28 AM | #12 |
Jamie Hyneman is my twin
I make step-sister connections like this every time I hook into the fuse box or make a ground connection. It makes the next electrical job easier.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
