Old 12-13-2005, 10:34 PM   #1
KTLX
Question Rear Window Gasket Help Please
All, I went to put a sliding window in my cab, large window, no trim, followed the direction, used plenty of dawn dish soap and could not get the window to go in. I wound up tearing the gasket to shreds on the inside. Any suggestions. Process I used, put the gasket on the sliding window. Put a small cord in the inside track, held the window up and pulled the cord from the inside. Zip, Zilch, Nada, a royal pain and very frustrating. Before I call the glass shop, is there a better way.
Kenny
KTLX is offline   Reply With Quote
Old 12-13-2005, 11:02 PM   #2
incoma
incoma's Avatar
Re: Rear Window Gasket Help Please
You're doing it the right way. Did you have someone pushing on the back side of the glass? I found that the pressure helped "pop" the glass in. Also, try one side at a time. Once you get one corner in, you can slide the window into that corner, and that gives you a bit more room to work with on the other side. I'll be reinstalling mine in a few weeks. A buddy got a bit overzealous when installing mine, and the string tore my rubber too, but not enough to cause a leak. I'm just an an@l guy you wants his truck to look right.
incoma is offline   Reply With Quote
Old 12-14-2005, 11:04 AM   #3
KTLX
Thanks for the assitance, I went an bought a new gasket, as I am the same way, I cant stand things that dont look right.
Kenny
Old 12-14-2005, 11:52 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Use Goop or GoJo hand soap and not the dishwashing detergent. It clings better and doesn't run off.
Old 12-14-2005, 11:57 AM   #5
truckdude239
truckdude239's Avatar
u need an helpper outside pushing on the window i did the string trick expect i used weedeating line it seem to work great
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-15-2005, 01:18 AM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Does an old gasket work, or is a new gasket required for pliability?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 12-21-2005, 01:35 PM   #7
KTLX
I would use a new gasket, I couldn't imagine using an old gasket with as much trouble as I had trying to get the gasket to fit on the inside of the cab.
Kenny
Old 12-21-2005, 01:39 PM   #8
John Fabris
TOTY 2006
John Fabris's Avatar
What was tearing the gasket? It you kept pulling the string thru the gasket, go with a bigger string (small rope)...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 12-21-2005, 08:37 PM   #9
KTLX
I used weedeater line, .085, and it sucked. My thought was it ripped the gasket because it was too tough/ridgid. Going to try again, I called a local glass guy Safelite and they will not install 3rd party glass (sliders). They say it breaks too easy. Oh well, back to the drawing board.
Kenny
Old 12-21-2005, 09:33 PM   #10
CG
BlahBlahBlah
use clothesline cord. can get it anywhere. its soft and not too big around.
