Old 12-13-2005, 11:32 PM   #1
chevymaz
What are you looking at?
chevymaz's Avatar
reinstalling lower door trim
Well I went thru one of those touchless car washes the other day when the weather was nice and I'll be damned if the fan that drys the vehicles off when you are leaving didn't blow a couple of lower pieces of trim on the passenger side of my truck . I got most of it back on but I am having a heck of a time getting my big hands behind the lower door hinge to remove the bolt that holds the piece that the trim attaches to. Is there a trick to removing this piece without removing the entire door or do I need a certain wrench to make it easier? Maybe I need to see if my better half can get her hands in there.
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
chevymaz is offline   Reply With Quote
Old 12-14-2005, 09:50 AM   #2
Huck
Huck's Avatar
Re: reinstalling lower door trim
This is like almost impossible. I've tried all sorts of ways with no simple solution. When I restore today, I eliminate the screw-bolt clip and use a spring loaded type. I also have used double sided 3M foam backed tape on lower trim with great results. If you can get a small wrench on the little bolt, but can't turn the wrench, I would rotate the clip from the outside and remove it. Then replace it with a spring loaded or 3M tape. IF your truck has nice paint, and the door is aligned really well, I would drill out the POS before I would remove the door. My .02!!
Huck is offline   Reply With Quote
Old 12-14-2005, 06:11 PM   #3
Green Machine
Green Machine's Avatar
I've cussed that problem several times. I would like to know how the factory did it. Marking the postion and removing the three hinge bolts on the bottom hinge has worked for me. It requires a very patient helper to hold the door while your're doing it so you don't wreck or scratch anything.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-27-2005, 03:06 PM   #4
chevymaz
chevymaz's Avatar
where do you buy the spring loaded pieces that hold the trim on?
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
Old 12-28-2005, 08:27 AM   #5
see ten
WTB this ad
see ten's Avatar
I dropped my inner fenders and went in from the wheel well. Took forever but it worked. BTW the door will be closed for this process.
see ten is offline   Reply With Quote
