Old 07-13-2002, 10:41 AM   #1
tim m
Transfer case id
Can anyone help me ID my transfer case, it's in a 70 K10 there is a set of numbers on the case they are C99404 then a W underneath?
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 07-13-2002, 03:15 PM   #2
nu2-72
An NP 205 will have a three bolt cover, center rear. The NP 203 was used 71-79. NP 205, 71-91. Np 208, 81 up. NP 241, 88 up. Early GM's used Dana 20. All info from Advance Adapters. What tranny ? Go to www.advanceadapters.com
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 07-13-2002, 05:20 PM   #3
Beast388
Suburbans RULE!
Beast388's Avatar
I would say that it is a NP205. The number on mine is C-99404 with a A1Q underneath.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 07-13-2002, 10:35 PM   #4
Rod
Pic of a 205 TC
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-13-2002, 10:42 PM   #5
fender
NP 203 was used from 73-79
NP 205 was used from 70-91 I believe
The rest is correct
it takes many nails to build a crib, but only one screw to fill
fender is offline   Reply With Quote
Old 07-14-2002, 12:34 AM   #6
too many
too many's Avatar
Thumbs up Top-side ID
When I was building my '80 1 ton 4x4 daully , I found a "quick" way to ID 203s & 205s. The shift handle on a 205 is round all the way thru floor. A 203 is rectangular . I was looking mainly at 70s and early 80s stuff. Any exceptions anyone knows of?
too many is offline   Reply With Quote
Old 07-14-2002, 12:41 AM   #7
nu2-72
Fender, as quoted, "all info from Advance Adapters." Those folks know more than I ever will.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 07-14-2002, 08:43 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
ford and dodge may have used NP203, but GM did not start until 1973 and the dana20 was only available in K5 w/ 6cyl and manual tranny.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-14-2002, 08:50 PM   #9
nu2-72
Interesting. The info from Adv. Adapters is listed just for GM/GMC trucks and Blazers.
What I should have said was that those people and many on this board know more than I ever will. Still learning.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
