Old 04-17-2002, 08:14 AM   #1
1968GMC
love my truck
1968GMC's Avatar
Post edelbrock carb 1406 ajustment questions
I just started my truck after instaling edelbrock cam, intake, carb. this was at 2:30 am so I was in a rush. I did not hook up the choke yet. When I press the gaz pedal it stalls, I have to rev it by the carb thigny. Also the top part thigny closes when i give it gaz fom inside the tuck then stals then wont start. I have to go to the carb an open the top thigny then it will start. Is it cause I dont have the choke hooked up? Also where do youwire up your choke? Can you hook it up to the fuse box. Im assuming to a fuse terminal key on power on key off power off.
1968GMC is offline   Reply With Quote
Old 04-17-2002, 08:50 AM   #2
69 longhorn
Post
you should be able to hook the wire to ign unfused in the fuse box. As far as any adjustments,go to edelbrock site under carbs,& you should find all the tuning info that you need.... http://www.edelbrock.com/
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
