Old 12-14-2005, 07:41 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need some help...
Here is what I have . I swapped a 454/th400 combo in place of the 350/th350 combo the drive shaft lenght is great but the th400 yoke is way bigger that=n the th350 yoke is there an adapter style u-joint that will marry the th400 yoke with the th350 shaft?? Any help would be great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-14-2005, 07:57 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Need some help...
Yes sir, it's called a conversion u-joint. If you can't find the part number right off, I have it outside in the shop and I'll go get it for you.
It's a u-joint with 2 big cups and 2 smaller cups. Available at any local parts store for about 15 bucks.
Old 12-14-2005, 11:22 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Thanks TX I will have to hit up the local parts house friday.. BTW thanks for the write up on the b.b. mounts on the cheap it worked out great..
MEMBER #6377
Project "7DEUCE"
