12-15-2005, 09:49 PM | #1 |
lifter noise
In the morning when it is cold my lifter are very loud untill they pump up is this normal?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
12-16-2005, 12:07 AM | #2 |
Re: lifter noise
never had that problem in any of my trucks back home in PENNSYLVANIA. what oil weight are ya running ? might have to go down to a 5w-30 or so to get it flowing quicker.
12-16-2005, 12:21 AM | #3 |
Re: lifter noise
depends on how old the motor is i'd never run 5w 30 in our trucks i'd run an min of 10w30 i run 10w40
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-16-2005, 12:30 AM | #4 |
Re: lifter noise
Oil filter plugged ?? I'd change oil to a 10w-30 and put on a good Wix/NAPA oil filter and try that.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
12-16-2005, 10:09 AM | #5 |
Re: lifter noise
not oil filter changed it like 3 weeks ago (I use wix) did the same thing before and after. gets good pressure I could go down to 10w30 next winter not going to mess with it now. It has roller rockers not sure what kind of lifters.
but the valve train is kind of noisey anyway I dont think it will hurt to much do i?
12-16-2005, 10:19 AM | #6 |
Re: lifter noise
just sounds like stiff oil to me because after it warms up it goes away right? durning cold weather the oil is stiff i.e. hard to push around so your lifters gona make noise till the oil loosens up. just my 2 cents
12-16-2005, 12:18 PM | #7 |
Re: lifter noise
That is exactly what it is truckdude so I dont think I will worry about it to much maybe next winter I will go with 10w30 in the winter.
12-16-2005, 01:21 PM | #8 | |
Re: lifter noise
You will eventually collapse a lifter. They are clattering because there is no oil in them to pump them up. Why are you not willing to run 10W30 now? Do you have a stockpile of the thicker stuff? It will eventually cause problems so if it was mine I'd switch oil now and I'd also go check the lash on the valves cold because you have some too loose otherwise they'd stay pumped up. Pull the valve cover and look for loose rockers (you'll have to spin it over to look at all of them closed) and when you locate the loose ones you'll have the clattering ones during cold starts, and give em a 1/4 turn. That will thinner oil will fix it as well prevent no oil at startup. if it is that thick the bearings aren't getting oil either and that will cause a problem. |
12-16-2005, 03:36 PM | #9 |
Re: lifter noise
Well I will have to look in to it. I am not a big fan of anything lighter than 10w40 in these motors (really like to run 20w50). I did not realize it was so seriuos most of the people I talk to said as long as goes away in a couple of minutes after cold start not to worry about it.
12-16-2005, 03:51 PM | #10 |
Re: lifter noise
I run straight 50 or 60 weight, but I lived in tucson and it was 110 degrees. I now run a 5w30 in the winter. the lifter has a spring inside it and when it fills with oil the spring doesn't bear the wight of the valve and spring, but with no oil in it the lifter comes up and the pushrod comes down, thus pushing that spring all the way compressed, over time the spring can break or loose its ability to spring, and again a thick oil does not circulate through the motor which starves bearings and such for oil. Idealy an oil pan heater could be used to pre-heat the oil before firing it up. Check the lash and use the thinner first number (it is only 5 or 10 weight untill it warms up, then it thickens up to 30 or 40 depending on what the bottle says) Look for 10w40, but I'd shy away from 20w50 if it gets real cold (it has been 3, 5, 7 degrees here in the mornings so I use 5w 30). When it warms up I'll switch back to 20W50 or straight 50. This is really only my opinion as are those of the guys saying it is OK, but I always err on the side of caution, because I am not willing to trash a motor on someone else's advice.
12-16-2005, 07:49 PM | #11 |
Old Skool Club
Re: lifter noise
I have seen people use Risolone in the crankcase (comes in quart cans) of engines that had a lot of noisy lifters....any noisy lifters, for that matter. When I was pulling wrenches for "the world's largest department store", the shop boss would offer up an "enema" for an engine that he deemed needed it. Seems like a can of Risolone, a quart of diesel oil, a quart of kerosene, and a couple cans of something else, after which he would start the engine and let it idle for 30 minutes, then drain the oil and change the filter. This procedure was supposed to clean the engine. I wouldn't know. To me, the only way to clean one that is all gunked-up, is hot tanking it. Then, you will know it has been cleaned out.
Some people also pour additives, like Risolone, down the carburetor...which will cause some intense smoke to emenate from the exhaust system (do it oudoors, for sure!). Some will do that with half the can, then pour the rest in so that the engine floods and dies. Then, after it sets for a while (I don't know how long), it is restarted. Whether or not this or any other miracle treatment additive will, or can, help a sticking lifter is debatable. I'll bet that there are lots of people who will chime in and say Bardahl, or Wynn's Top Oil, or whatever chemical is their favorite, is the only way to solve the problem. At the least, you've just wasted a couple of bucks.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-16-2005, 08:19 PM | #12 |
Re: lifter noise
timed it today, was in mid 30's dark stiff wind about 10 hours sitting. Tapped mid-loud for 5 secs and was completely gone by 15 secs. (seemed longer before I timed it LOL)
12-16-2005, 08:32 PM | #13 |
Registered Cruiser
Re: lifter noise
When I start mine in the morning I'll crank it over 'till I have oil pressure, then pull the choke and fire it up.
I intend to live forever. So far, so good. |
12-16-2005, 11:10 PM | #14 |
Re: lifter noise
20w50 is way to thick for winter driving change it out asap.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
