Old 12-16-2005, 06:40 AM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
4 head lights to 2
what's all involved with going from a 4 headlight setup (1989) to a 2 headlight setup (88-91)? I'm thinking:
core support
grill
left and right trim pieces
Anything else? What would need to be done with the wiring?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-27-2005, 11:06 PM   #2
beaterC10
Re: 4 head lights to 2
I can't comment on the parts list, but it would prolly be cleanest/easiest if you find the light harness that matches the lights you intend to use. I have installed a four light system from an 87 on a 77 cab and simply used the light harness from the 87. The wire color codes were different, between the two years, but the pin out at the firewall plug was the same.
beaterC10 is offline   Reply With Quote
