Old 12-16-2005, 09:38 AM   #1
70GMCer
70GMCer's Avatar
Bed side help
Is there a faq on how to remove the bedsides of a 1/2T fleetside (lwb)? Someone told me that they are bolted on and come right off....
steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-16-2005, 11:45 AM   #2
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Re: Bed side help
Steve:
You can check the online instructions we have for the steel-to-wood bed floor conversion. http://www.mar-k.com/67-72conv.pdf The first 2 or 3 pages are disassembly procedures.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 12-16-2005, 05:23 PM   #3
70GMCer
70GMCer's Avatar
Re: Bed side help
thank you....
1997 GMC Sierra Ext
1965 Mustang
Old 12-16-2005, 05:28 PM   #4
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Re: Bed side help
It's Actually Easy, Just Unbolt It From The Headboard And Then Follow Down The Length Of The Bedfloor. I Like To Unbolt The Wheel Well From The Floor Rather Than From The Bedside. There Are Two Welds At The Back Of The Bed Where The Bed Connects To The Rear Crossmember Of The Bed Floor.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 12-16-2005, 06:09 PM   #5
70GMCer
70GMCer's Avatar
Re: Bed side help
Kinda thought it would be easy....just wanted to double check before starting. I might have to replace the left side and wanted too know about this...
1997 GMC Sierra Ext
1965 Mustang
Old 12-16-2005, 06:49 PM   #6
Huck
Huck's Avatar
Re: Bed side help
REplacing a bedside is easy but you can't just bolt up the replacement. You have to line it up and check it's position before bolting it down. You need to have the correct position, left to right, tilt left to right etc.. You actually need to measure it from opposite front corners to get it square or you will go crazy with the tailgate positioning. So, attach the bolts but align before you tighten them~!!!
Huck is offline   Reply With Quote
