12-16-2005, 01:07 PM | #1 |
Swithed to a hotter t-stat, now..
the truck is running like dog poop. Idles rough and the the coolant temps are all over the place. How would switching out a 180 stat for a 195 stat cause all this?
I'm guessing the computer is trying to adapt to the new stat??
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
12-16-2005, 01:15 PM | #2 | |
Re: Swithed to a hotter t-stat, now..
12-16-2005, 01:37 PM | #3 |
www.73-87chevytrucks.com
That is weird, the '87 takes a 195 stat.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-16-2005, 03:57 PM | #4 | |
capt., 180 stat is all I've ever used in the truck. I was under the impression that 195's were for colder climates. Anyway, I put a 180 stat back in and the truck is running better.
12-16-2005, 04:59 PM | #5 |
Parts and more parts
doesn't sound like a T/stat to me. It sounds like you have water in that high priced gas that you have. I used to switch to a 195 T/stat for winters and then I got rid of the older truck. I live North of you about 300 miles and I run 180 degree T/stats all of the time. If you don't have a heating problem (due to a really big radiator) then you should not have to swap out the T/stat. If your heater is plugged, then changing will help some. As for your running rough, check for a good spark and then run some gas line treatment in the tank. If it has a EFI setup then put in some injector cleaner. ( The coolant temps are all over the place) Did you use a "Super Stat". If not then what you are experiencing is the T/stat full closed and then it "POPS" off of it's seat and then it is full open. (Run hot then run cooler) A "Super Stat is made to modulate better and then the temp is more controlled. Check with any Auto parts outlet They carry them under their name usually. We have NAPA, Carquest, and O Reilly's around here.
12-16-2005, 05:04 PM | #6 |
1968 C20 Vortec Beast
The computer controls fuel mixtures by reading engine temprature. The factory is a 195. Now, if a hypertech chip is installed in the ECM it requires a 180.
Ugly or not it still kicks a**! |
