12-17-2005, 06:49 PM | #1 |
need id on frontend
I found the number on the front axle but can not find out what it is. The build number is 60333-3. I think it is a Dana 44 ????
12-17-2005, 07:02 PM | #2 |
user # 2756
Re: need id on frontend
easiest way to tell is, a raised "44" in the lower right webbing on the center section as you look at the front of the vehicle, a 10 bolt has ears on the lower left and right of the center section, finally a dana 60 mounts with 3 u-bolts and 2 studs, the other two use 4 u-bolts.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
12-18-2005, 08:01 AM | #3 |
60333 is not a valid Dana BOM number. It should be six digits. Look a little closer.
Tim |
12-18-2005, 09:48 AM | #4 |
Did a quick search on the Dana expert for 603, and it comes up with a Jeep axle. The expert only goes back till 77 or so, so if it's an older axle it won't come up.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
12-18-2005, 07:29 PM | #5 |
Sorry I left a number. It should be 603333-3. It is suppuse to be a 1972 frame and suspension.
12-18-2005, 11:43 PM | #6 | |
12-19-2005, 07:52 AM | #7 |
I don't see 603333 anywhere in the '67 - '78 Dana catalog.
Tim |
