Old 12-17-2005, 08:27 PM   #1
7tcutty
olds motor swap
hello all
ive decided to put some olds power in my truck
455 into 86 k10 truck
id like to know has anyone done this before and what motor mounts and frame mounts will i need to use. i have some from a Firebird. i also plan to use the 700r4 rebuilt with a shift kit. this truck is gonna get driven and its also a plow truck tow rigg and pretty much everything truck.. everyone tells me the 700 wont last behind that big block.
but no one can tell me WHY! i wont be beating the crap out of the truck i just want some TOURQE and with the 373s it should pull stumps
and if anyone has a oe adapter plate for a bop to chevy i could use one!
thanks to all
karl
7tcutty is offline   Reply With Quote
Old 12-17-2005, 11:29 PM   #2
f.monroe
f.monroe's Avatar
Re: olds motor swap
I dont know anyone who has done this but have seen late 70's diesel trucks converted to gas . The diesel was olds 350 based and an olds gas engine was the gas engine of choice once the diesel was dead . If you could find one in a junk yard , that should provide you with the mounts , etc to allow you to bolt it in . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 12-17-2005, 11:48 PM   #3
pugs
pugs's Avatar
Re: olds motor swap
Dont quote me on this but are ya sure the 700r4 will even bolt up to the 455 and im also not possitive but i thought the starter boltesd up on the left side of the engine again dont quote me on this info
Pugs
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 12-18-2005, 01:10 AM   #4
7tcutty
Re: olds motor swap
the 700 will not physically bolt up to a BOP engine you must use an adapter plate to make that part work as far as the starter goes i may be put on either side of the trans as they are notched for such.
finding those 5.7 diesel truck are like finding a needle in a haystack. whats make it worse is that there are no"GOOD" YARDS in my area. i keep looking thou hoping to find that needle
Old 12-18-2005, 01:47 AM   #5
pugs
pugs's Avatar
Re: olds motor swap
speaking of a diesel i had looked a swb one this past fall i believe it only had like 30 some k on it and the guy was if i remember right was 4 g's the truck could have used alitle paint but overall it was rustfree
Old 12-20-2005, 12:25 AM   #6
86k10
Re: olds motor swap
I done it about 8 years ago. It's been a very enjoyable swap.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 12-20-2005, 12:37 AM   #7
wibilly
wibilly's Avatar
Re: olds motor swap
86k10 are you using a 208 t case with that set up and how do you like that case if you are
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-20-2005, 12:48 AM   #8
86k10
Re: olds motor swap
Yes still have the 208 and like it fine, they are a good case just keep them full of oil in fact it's a good idea to add a little extra. The way I done it was to back the rear wheels up on ramps and then fill it up. The reason is they have an oil pump on the output shaft and the level needs to be high enough to keep oil to it. Oh filling it to the plug is fine too but I like that little extra cushion. When I done the swap my truck had around 170,000 and still had the original trans. Now it's got 235,000 and still the original trans.
98 Neon
97 Grand Prix GT
86 GMC 5.0
77 Olds 98 6.6
Old 12-20-2005, 09:12 AM   #9
7tcutty
Re: olds motor swap
86k10
what do you use the truck for just every day driving or do you tow and or plow with it.
what motor mounts did you use for the swap,
were there any problembs with bolting evry thing togeteher
what trans adapter did you use im looking at the one thats on ebay.
your help is greatly appreciated id like to be able to get everthing done in a couple of days if at all possible.
oh one last question how do you like those 410s and lim slips front and rear i am thinking about the same setup only with 373s
THANKS!!!!
karl
Old 12-20-2005, 10:30 PM   #10
86k10
Re: olds motor swap
Oh it's everything from a daily driver to on occasion doing some towing, only wish I had a snow plow for it. All I did for mounts was take what I call the mount stands from a V8 car of about 74 vintage. First I took a bare block so as to not be to bulky and after installing the B&M adapter plate, bolted it to the trans so I knew where the mounts needed to be and with the mount stands attached to the motor mounts just lowered it onto a piece of 1/4" plate that is bolted with the bolt holes for the Chevy mounts, then mark and drill hole for the Olds mount stands. I'll try and get a pic or 2 of it all so you can kind of see what I mean. It all fit in very nicely even though the starter is on the opposite side, I just took the main harness and separated the wires and rerun then so they looked pretty decent. I drove it up until about 2 years ago with the factory 3.08 gears and got along great, then wanted to try deeper gears just to see the difference. the way it is now it has a ton of pulling power and can still go as fast as needed on the road, I've been very happy with it. As far as the no spin axles, well let's just say that makes it a real 4X4, very nice indeed.
98 Neon
97 Grand Prix GT
86 GMC 5.0
77 Olds 98 6.6
Old 12-26-2005, 01:40 PM   #11
7tcutty
Re: olds motor swap
i would appreciate any pics you can get to me my email is williaka@iserv.net
this will be a spring project for me and im gathering parts still.. i looking at a powertrax for the rear and lateron down the road a lsd for the front then all probably got to a 285/75/16 tire for a little more height but the truck will be a hell of a tow rigg by then!.. btw do you know where i can find the schematic and harness to convert the truck to a 7 round trailer plug? then i can use my prodigy
thanks again 86k10
karl
Old 12-26-2005, 08:28 PM   #12
86k10
Re: olds motor swap
Yes I will try to get you some in the next day or so. I don't have a first class camera but i'll do my best. Oh and don't listen to these ( better not use that word) who say the 700 will not hold up behind a big block. Most of there durability is up to the builder and IMO not just any know it all off the street can do a proper job of building one. I've been toying with them for going on 20 years now and have had very good luck with them and never stop learning new things that work and don't work.
98 Neon
97 Grand Prix GT
86 GMC 5.0
77 Olds 98 6.6
Old 04-23-2007, 11:37 PM   #13
7tcutty
Re: olds motor swap
this is an old thread i started and im bringing it back to the top still looking for information on this
now plans have changed i have a powertrax in the rear looking to LIFT the truck with 456s and locker in the front also.. the plow will be comiing off of the truck also
I also have mount stands from a diesle truck and will be buying a BUILT 700 for this truck.. looking to build a dependable truck for CHEAP
Old 04-23-2007, 11:48 PM   #14
BaddBusa2005
BaddBusa2005's Avatar
Re: olds motor swap
they have a BOP 700r4 if you can track one down.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 04-24-2007, 12:09 PM   #15
Pyrotechnic
Pyrotechnic's Avatar
Re: olds motor swap
2004R will bolt right up to the motor and can be built just as strong as a 700, but 1st gear isn't as low.
If you want to go through the trouble of an odd motor swap, why not do a Cadillac 500 ? The high nickel content in these blocks mean the will last a VERY long time and you often find them with the original cross hatching and no ridge in the cylinder bores. You can pick up a rebuildable 472 or 500 at junkyards for very cheap.
If you stay relatively stock with just small upgrades the it'll be just as cheap as any other engine rebuild. You get MASSIVE low end torque that will move your truck down the road and get great gas mileage, even while towing. This torque will also be great off road.
Pyrotechnic is offline   Reply With Quote
