Keep On Truckin'
Seen the polished stainless steel tailgate top edge protector and the stick on rubber molding that LMC sells. Are there any others out there, if so do tell, please......
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
![]() Join Date: Jul 2001
Re: What are the tailgate top edge protector options??
I installed a '73 and newer diamond tread plate style on my '71 tailgate. The '73 and newer 'gates are a bit thicker so I had to "spread" the metal a bit to make it fit. Worked out well and looks good. I looked at the smooth stainless protector and it just looked "to plain" Fastened it down with 4 or 5 self tapping screws.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
I had a polished stainless steel tailgate edge protector on my truck that the previous owner put on and I took it off, if anybody wants it they can have it for the freight charge.
![]() Join Date: Dec 2002
I could sure use the tailgate edge protector, Fastfun.... What would the shipping be to zip 97233 ( Portland, OR!!....)
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
You have first dibs
I will have to measure for a box and weight and I will let you know. thanks |
67-72 Addict!
I have the polished stainless one from PUTCO. My dad has the 4 piece kit from LMC on his bed.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
