Old 12-18-2005, 11:53 AM   #1
fossilrunner
fossilrunner's Avatar
mini spool
anyone running one of these on the streets?
71 chevy lwb w/ 350,750 holley 4150,edelbrock performer rpm,full 2 1/2 exhaust exit out side,6-8 drop,rally wheels.-SOLD
74 Chevy nova-355 with a little nitrous
78 GMC Jimmy 4x4-Factory 400 and all stock.
fossilrunner is offline   Reply With Quote
Old 12-18-2005, 12:00 PM   #2
cdowns
cdowns's Avatar
Re: mini spool
not suited for the street a waste of money
Old 12-18-2005, 12:05 PM   #3
cableguy0
Re: mini spool
definately a bad idea on the street.if you want a posi get a clutch style like eaton or similar and it will allow you to safely make turns
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-18-2005, 12:10 PM   #4
jhow66
jhow66's Avatar
Re: mini spool
Ever ride a go-cart?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-18-2005, 12:19 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: mini spool
I got one in my toyota but its not a daily driver and with the rear end locked up it is down right scary to drive in the rain.. Bad idea for sure..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-18-2005, 04:18 PM   #6
Green Machine
Green Machine's Avatar
Re: mini spool
If you need to turn corners its not a good idea.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-18-2005, 06:48 PM   #7
muddpile
muddpile's Avatar
Re: mini spool
I had a friend install and remove one once. NOT safe for a driver.
muddpile is offline   Reply With Quote
Old 12-18-2005, 07:16 PM   #8
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Re: mini spool
I ran one on the street in a lifted 4x4 it was okay, exept in the rain, or on tight u-turns, other than than that it would just drag one of the tires in th turns not bad, but if it was primarily a street driven truck I'd buy a posi, or one of the lockers the replace the spider gears. On the 67-72 chevy trucks if you add one extra shim be hind the spider gears it will act like a limited slipm I have done this many times.
farmtruckIII is offline   Reply With Quote
Old 12-18-2005, 08:43 PM   #9
crazy longhorn
Fabricate till you "puke"
Re: mini spool
I did , & it was lots of fun! That old fox racer had a live axle......it turned just fine if you had it @ full throttle this was on a dirt track.....& it was d@mn hard to steer the corners if you let up on the loud peddle! if you want the mini spool for off road 4 wheelin , or dirt racin, go for it.........on the street, it will be D@MN HAIRY! L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
