Old 12-18-2005, 01:26 PM   #1
68350
68350's Avatar
Monojet problems, need help
I have a 250 I6 with a one barrel monojet and I can't get it to run right. It will idle fine and then it will just start losing idle and die. It dies even faster if you let the clutch out(3 on the tree). Is there a secret tuning step or something? Thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-18-2005, 03:10 PM   #2
zeeklu
Re: Monojet problems, need help
Not much to tune on them. Did you check and see if the manifold is tight where it meets the head? Try looking for other vaccuum leaks.(carb base, vac lines throttle shaft) Chris
zeeklu is offline   Reply With Quote
Old 12-18-2005, 03:35 PM   #3
68haywagon
I'm watching you!
I had something like that problem before I rebuilt my carb. After the rebuild that problem went away, but others popped their heads out. Did you rebuild it yet?
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 12-18-2005, 07:38 PM   #4
tkeduk8r
tkeduk8r's Avatar
eaziest carb ive ever worked on.... tear it down, buy a 1 gal can of the good carb cleaner (only at autoparts stores, round these norhtern parts try auto value) and soak it all.. a good "standard" rebuild kit, and new float... blow it all out, and set everything up to fac specs... will work like a charm.. i did mine on my 74 and worked beautifully... need any help let me know....
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
