67 Shortstep
Brake Job on My '67 Shortstep
I plan on doing a complete brake job on my 67 Shortstep. I have the original 6 lug drum setup front & rear. I just recently aquired the truck & was told that it had been sitting up a while. I'm assuming that it currently has DOT 3 fluid in the system now, but it looks pretty funky. If I replace all 4 wheel cylinders, blow all the brake lines clear, & empty the master cylinder, will it hurt anything to go back with silicone brake fluid? Are there any advantages to using silicone brake fluid vs. DOT 3 fluid? Or do I need to just stick with the DOT 3?
67 SWB Step 69 LWB CST 71 LWB 94 SWB Step 05 1500 Dodge P/U Adapt, Improvise, Overcome ![]() |
Re: Brake Job on My '67 Shortstep
silicone brake fluid is desinged for todays vehicles higher temp. braking systems. it WILL work in older applications, for the price, i still use dot3. from Andyman1-cert. ASE brake tech.
67 Shortstep
Thanks andyman....This truck is for my son to drive back & forth to school, so I was just thinking that the silicone fluid would make the brake system 'er'...Just didnt know if its too much sugar for a dime...
blood type; Retumbo
also just draining the MC and blowing out the lines will NOT get all the old fluid and "crud" out. it will mix with the silicone & create havoc.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
67 Shortstep
So the best thing overall to do would be empty the system as much as possible & go back with DOT3, right?
#6 | |
That is what I would do. No real increase to be had from anything else. I could see if you swapped in C5 suspension and brakes. |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Watch out for your cornhole !
![]() Join Date: Jun 2003
The advantage of silicone is that it's not hydroscopic. That is, it does not absorb moisture from the atmosphere. That makes it ideal for infrequently driven vehicles too.
