Certified Pud Puller
ECE drop crossmember
who here has early classics drop crossmember on a long bed? i talked with there tech guy and he said it is possible to run run i was just wondering if anyone had pictures of how they did it.
1997 Silverado extended cab- mpfi conversion, 22" kmc's 1983 C10- some assembly required 99.5 F250 Super Duty 7.3 5" straight pipe, wicked wheel, ts tuner, ccv mod, 4" lift 315/75/16s |
Re: ECE drop crossmember
I far as I know there wont be a difference between longbed and shortbed other than the crossmember is under the cab on a shortbed and behind the cab on a long bed.
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles Last edited by DM310; 12-20-2005 at 04:56 PM. |
You would need to either have a one piece drive shaft or rig up a mount for the carrier bearing on it.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
