Old 12-20-2005, 01:09 AM   #1
FormerMember
86 Camaro rear calipers with mounting brackets and ebrake cables.
Just got the set up I really, really wanted.
These can go. Use them with a 95 Caprice rear rotor and you're good to go.
Could fit other rear axles with a different mounting bracket (weld on, etc).
I'll sell them for what I paid for them:
75.00 plus the ride. This includes all the ebrake hardware.
Funny thing, I seem to be going through a ton of rear ebrake calipers... Bolt holes are 3" apart, fit on most 10B's.
FormerMember is offline   Reply With Quote
Old 12-20-2005, 03:24 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: 86 Camaro rear calipers with mounting brackets and ebrake cables.
I'm sorry, you are saying these will bolt on to a truck of our year? Just use a 95 Caprice rotor? Thanks and sorry for the confusion, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-20-2005, 03:30 PM   #3
FormerMember
That is what I was going to do with them, yes.
There are several 10B bolt patterns.
Old 12-20-2005, 03:46 PM   #4
red71cheyenne
Back in the sticks
Cool! I had no idea something off a newer car would fit including the backing plate. I thought thats why everyone sold custom made ones. Thanks, Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-20-2005, 03:51 PM   #5
FormerMember
Well, it's a 10B, there are a few mounting hole differences between the years, but nothing a drill couldn't fix! To run these on mine, I would probably use a different caliper mount, as I have "the big hole 10B (4" apart for the mounting bolts)". Calipers are still worth the fundage though, as all the ebrake stuff is there and works well.
Sad, isn't it? These would work fine, with little work but be uglier.
Old 12-21-2005, 03:08 AM   #6
FormerMember
Originally Posted by rick980
What are the measurements center to center on the bolts of the backing plates?
3" (as listed above in the first post)
Of course, if you happen to have the 4" 10B re-drilling isn't an issue. There's plenty of meat.
The rotors are 18.99 at Autozone.
Heck, aftermarket caliper brackets for these calipers are 12.99 each!
http://www.loufegersracing.com/49.html
Old 12-21-2005, 08:37 PM   #7
70short/step
70short/step's Avatar
So what setup did you get that you really wanted?? I am thinking disc brakes in the back but dont know what direction I am going yet.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 12-21-2005, 08:51 PM   #8
FormerMember
Brembo with slotted and drilled rotors.
Old 12-21-2005, 11:19 PM   #9
skeeter288
why cant rear caprice setups work? why would you need camaro plates & calipers and caprice rotors? i thought rotors off caprice were 4.5 in bolt pattern where the truck was 5 inch.
skeeter288 is offline   Reply With Quote
Old 12-21-2005, 11:25 PM   #10
FormerMember
No one said they wouldn't work.
In fact, some here are running the 94-96 Caprice/Impala rear disk which is 5 on 5". Ebrake's built into the backing plate, from what I've been told. May need to build an adapter to bolt the backing plate on.
Why is this turning into a tech article???
Old 12-21-2005, 11:39 PM   #11
skeeter288
sorry. i didnt want to upset anyone. i just dont want 2 different bolt pattern wheels. thanks.
Old 12-22-2005, 09:06 AM   #12
FormerMember
Not upset. Just trying to keep it in-line with the board it's posted on.
Old 12-24-2005, 11:19 AM   #13
FormerMember
Ttt
Old 12-27-2005, 11:49 AM   #14
FormerMember
tripped over these yesterday... please make them go away!
