Old 12-20-2005, 01:26 AM   #1
SCOTI
SCOTI's Avatar
Close-Up pic wanted of FatMans Stage III
I'm curious about a couple of details on the FatMans Stage III, IV, or V front end kits.
I was wondering if anyone here has this set-up on their truck if it would be possible to get a few shots of how the upper a-arms mount in relation to the top of the frame? It must be the Stage III or better (either coil-over or Shockwave) because they utilize the same upper mount from what I can tell in the catalog pics.
I'm curious to see if the truck kits are utilizing a similar set-up.
Thanks..... Scot
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-20-2005, 05:28 PM   #2
Bowtie67
Bowtie67's Avatar
Re: Close-Up pic wanted of FatMans Stage III
Thanks..... Scot
http://www.webrodder.com/article.php...8802e365d549d8
Have you checked out this link.. I just ordered a stage 3 front suspension from him. I ordered it with standard hight spindles which are supposed to be about a 4" drop. Everything here in less than 10 days, I prebuilt most of the front end on some saw horses in less than an hour. I am going to replace the complete frame with a 2x4 boxed rails setup that I am going to build. Will be starting after Christmas.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 12-20-2005, 09:24 PM   #3
SCOTI
SCOTI's Avatar
Thanks for the link. I had actually read that article before but the pics that came w/it weren't very clear @ the time.
I couldn't tell if the upper a-arm mounts were any higher than the factory GM a-arm mounts. It looks like they are pretty close.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-29-2005, 06:14 PM   #4
BigSky71
LAIDOUT
BigSky71's Avatar
So can you get "on the ground" with that FatMans M2 kit and airbags? I am assuming you can choose drop spindles and shockwaves for that setup.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 12-29-2005, 08:34 PM   #5
Bowtie67
Bowtie67's Avatar
You can order both drop spindles and airbags for thier front ends, they told me the 2" drop spindles really makes them sit pretty low with standard setup. Otherwise their normal setup is like a 4" drop.
2009 Toyota Tundra
