An American Soldier
![]() Join Date: Feb 2005
Does anyone sell windshields for our trucks that have an antenna in them? I don't want the factory antenna sticking out of my cowl. So, I am looking for other options.
Dan dan.brue@us.army.mil |
Re: Antenna in Windshield
Use a hidden antenna. Several comapanies carry them. I know for a fact that Dakota Digital has them, and I believe I have heard the brand Auto-Loc thrown around here on the board.
I am using the Dakota Digital and have it mounted behind my glovebox. Linky |
Heres another Ebay Linky
its all about the +6 inches
Or just mount your Antenna under the dash or under the cowl.
#5 | |||
Union Electrician
Longhorn has got on easy way there, but would it help/work to attach a piece of wire to the antenna and then to the cab itself to use the whole truck as your antenna? Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Back in the sticks
I once had one on the '71 that was just two pieces of wire you taped to the windshield in a hidden location. Don't buy this one! I got better reception without an antenna. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
I installed an antenna under the cowl, I have it grounded to the cab and I get poor reception. I am also trying to find an alternative.
Gary
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
GEARHEAD
Screamin C10, How do you like the reception on your hidden one?
HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
I had one under the cowl in the old GMC for a while. Didn't ground anything more than what was supposed to be. Had a piece of metal in there with a hole big enough for the Ant mount, had it bolted to the inner cowl, and it was bent over to where the Ant pretty much just laid across the front of the cab. Worked just as good as the one that I replaced it with when that portion of the cab fell victom to rust and the antenna fell into the cab.
![]() Join Date: Dec 2002
the radio chassis is grounded by the mounting....The anntenna is not grounded!....if grounded ; the reception will range from no reception to very poor.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
I thought I had read that somewhere... but wasn't sure. Thanks Jim.
#12 | |
It is about as good as the wife Focus. |
#13 |
Thats the Hillbilly way
I got one of the after market ones that attached to the inside of the windshield on bottom of the passenger side .
Best radio reception I have had in years.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
#14 | |||
Union Electrician
Bill, give up some info on this one. I haven't seen the type you refer to,only just the terrible looking stock ones from the 80's. Randy
#15 |
Putting the antenna element under the dash or cowl stacks the chips up against good reception, because you are surrounding the sensing element with grounded (chassis ground) steel.
With a regular FM antenna, the antenna cable is shielded until its connected to the antenna base. Thats when the cable shielding ends and is grounded to the body, at the antenna mount. (its also grouded at the radio connector, to radio chassis). At the antenna base, the center conductor (antenna) becomes unshielded, and depending on the antenna (or wire) length, gets tuned to a frequency. For FM radios, they usually make it a frequency in the FM band that corresponds to where most stations are grouped. Also, the right packaging length has to be considered and then a happy medium is reached. Typically in todays cars, that is about 31 inches, but in our trucks, the antenna was telescoping, so the best frequency could be chosen if you knew how to calculate it. Speaking of calculations, try this website: http://www.crompton.com/wa3dsp/hamradio/antcalc.html Oh cra p, I wrote another book (week b4 christmas, office is empty, boring) What I am getting at is you can literally make your own hidden antenna just by routing the antenna cable up into the cowl, or under the dash, then stripping back the coaxial cable braided ground, leaving about 31 inches (or whatever you desire) bared. Terminate the shield to chassis ground and try tucking the conductor wire inside the window seal. Totally hidden! - hey, and it really works too! - just don't let the antenna conductor touch chasis ground, or you will effectiveky shorten the length of the antenna.
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" Last edited by 72 longhorn BB; 12-21-2005 at 10:53 AM. |
#16 | |
#17 |
I have one of the hidden antenna's, I believe it's an autoloc. Works really good close in, fades fast when I head out of town, also, it depends which direction the truck is headed. It's a great idea in theory, but I'd do some research, I suspect not all hidden antenna's are equal.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
