Old 12-20-2005, 02:55 AM   #1
jeffbbc
Wheel base on short and long beds
What are the wheel base lenght on sb and long beds and do the duallies come in those same wheel bases? Can I get a dually flatbed and put a short or long bed on it with stepside sides on them? OR will the wheel base be different and I will need to modify the bed? I hope this makes sense. I am thinking of taking a one ton flat bed and making it into a beded dually
Thanks for your help
Jeff
jeffbbc is offline   Reply With Quote
Old 12-20-2005, 05:33 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Wheel base on short and long beds
SWB 115 inches
LWB 127 inches
Dualie 133 or 157 inches
Longhorn/9 foot step side.... 133 inches
If you get a one ton stepsidebed, or a longhorn bed, you can toss it on a 133 inche dualie. The stock rear end on these duallie trucks doesn't place the 2 added tires out, but rather in. The track width is only an inch wider than a single rear wheel trucks. So added senders won't be needed, just larger wheel tubs.
