Old 12-20-2005, 03:59 AM   #1
70' Chevy
How to determine rearend specs.
Someone give up some good tips on how can I determine what rearend the old truck has. I know it has 10 bolts in the cover (if i didn't miss any under the grime) but that is about all I know at this point. It needs a heavy duty degreaser and some high H2o psi. Sounds like it is geared low when running thru the gears. Also if it's a posi track could I jack it up and roll one wheel clock wise and the other go ccw or does it work differently?
70' Chevy is offline   Reply With Quote
Old 12-20-2005, 05:02 AM   #2
Americanrider
Re: How to determine rearend specs.
Since it's dirty clean it all the way and pop the cover, inspect & count the teeth, do the math, check wear pattern, wipe out all the sluge from the bottom of the housing, re-seal and re-lube. The only way to be sure what you have and what shape it's in. The general rule of thumb is most Chevs got Eatons and GMC's got the Dana 60, but there are exceptions to this rule. The Dana 70 is a Dually Rear from newer trucks, I just threw that in there to confuse ya.... Welcome from Rainy Washington state!
Note: DANA 60 top right, DANA 70 top left
Americanrider is offline   Reply With Quote
Old 12-20-2005, 11:32 AM   #3
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
There is also a three letter code (for the axle ratio) stamped on the front of the right axle. Only, problem is I can't remember what ratios go with what letters. Maybe someone else on the forum has that info. Once you clean up the axle you might post it and see.
Of course if someone has already changed the gears you'll have to follow American's advice anyway.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 12-20-2005, 10:49 PM   #4
These are the axle codes 1970 Chevy. I am not sure if they apply to other years or not. I can't rememmber where I found them, but maybe this will help.
Series-Code-Ratio-Plant
1/2-Ton-TDA-3.73:1-N/A
1/2-Ton-TDB-4.11:1-N/A
1/2-Ton-TDC-3.07:1-N/A
1/2-Ton-TDD-3.07:1-N/A
1/2-Ton-TDE-3.07:1-N/A
1/2-Ton-TDH-3.73:1-N/A
1/2-Ton-TDI-3.07:1-N/A
1/2-Ton-TDJ-4.11:1-N/A
1/2-Ton-TPF-3.73:1-N/A
1/2-Ton-TPG-4.11:1-N/A
1/2-Ton-TPH-3.07:1-N/A
1/2-Ton-TPI-3.07:1-N/A
1/2-Ton-TPJ-3.07:1-N/A
1/2-Ton-TPL-3.07:1-N/A
1/2-Ton-TPM-3.07:1-N/A
1/2-Ton-TPN-4.11:1-N/A
1/2-Ton-TPO-3.07:1-N/A
1/2-Ton-TPP-3.07:1-N/A
3/4-Ton-TAA-4.10:1-N/A
3/4-Ton-THU-4.10:1-N/A
3/4-Ton-THV-4.57:1-N/A
3/4-Ton-THW-4.10:1-N/A
3/4-Ton-THX-4.57:1-N/A
3/4-Ton-THY-4.57:1-N/A
3/4-Ton-TIA-4.57:1-N/A
3/4-Ton-TIB-4.57:1-N/A
3/4-Ton-TJS-4.57:1-N/A
3/4-Ton-TJT-4.57:1-N/A
3/4-Ton-TJU-4.10:1-N/A
3/4-Ton-TLN-4.10:1-N/A
3/4-Ton-TMZ-4.10:1-N/A
3/4-Ton-TNA-4.10:1-N/A
3/4-Ton-TNB-4.10:1-N/A
3/4-Ton-TOU-4.57:1-N/A
3/4-Ton-TOT-4.10:1-N/A
3/4-Ton-TTF-4.10:1-N/A
3/4-Ton-TWI-4.10:1-N/A
3/4-Ton-TYS-4.56:1-N/A
1-Ton-TID-5.14:1-N/A
1-Ton-TIE-4.10:1-N/A
1-Ton-TIF-5.14:1-N/A
1-Ton-TIG-4.57:1-N/A
1-Ton-TIH-4.10:1-N/A
1-Ton-TLJ-4.10:1-N/A
1-Ton-TLV-5.14:1-N/A
1-Ton-TLW-4.57:1-N/A
1-Ton-TLX-4.10:1-N/A
1-Ton-TLY-5.14:1-N/A
1-Ton-TLZ-4.10:1-N/A
1-Ton-TMC-4.10:1-N/A
1-Ton-TMR-4.10:1-N/A
1-Ton-TMX-6.17:1-N/A
1-Ton-TNW-4.57:1-N/A
1-Ton-TNZ-4.10:1-N/A
1-Ton-TRN-4.10:1-N/A
1-Ton-TVF-5.14:1-N/A
1-Ton-TVI-5.14:1-N/A
1-Ton-TVL-4.57:1-N/A
1-Ton-TVM-4.57:1-N/A
1-Ton-TVN-4.57:1-N/A
1-Ton-TVO-4.57:1-N/A
1-Ton-TVS-5.14:1-N/A
1-Ton-TVT-5.14:1-N/A
K1/2-Ton-TDF-3.73:1-N/A
K1/2-Ton-TDG-3.07:1-N/A
K1/2-Ton-TDH-3.73:1-N/A
K1/2-Ton-TDI-3.07:1-N/A
K1/2-Ton-TDJ-4.11:1-N/A
K1/2-Ton-TPK-3.73:1-N/A
K1/2-Ton-TPL-3.07:1-N/A
K1/2-Ton-TPM-3.73:1-N/A
K1/2-Ton-TPN-4.11:1-N/A
K1/2-Ton-TPO-3.07:1-N/A
K1/2-Ton-TPP-3.07:1-N/A
K1/2-Ton-TPR-3.07:1-N/A
K1/2-Ton-TPW-4.10:1-N/A
K1/2-Ton-TPX-4.10:1-N/A
K3/4-Ton-TGA-4.57:1-N/A
K3/4-Ton-TGB-4.57:1-N/A
K3/4-Ton-TPW-4.10:1-N/A
K3/4-Ton-TPX-4.10:1-N/A
K3/4-Ton-TPZ-4.57:1-N/A
Old 12-20-2005, 11:02 PM   #5
kingsolver72
10/30/19
kingsolver72's Avatar
Palf,that great info.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 12-21-2005, 01:39 PM   #6
Old Yeller 1970
DON'T TREAD ON ME
I knew someone was bound to have the codes, Thanks Palf.
Old Yeller
Old 12-21-2005, 07:51 PM   #7
72 longhorn BB
72 longhorn BB's Avatar
Can you please be a little clearer on where to find this stampig on the right axle?
I can not see mine
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 12-21-2005, 08:14 PM   #8
I could never find mind either. I think the rust and grease ate mine.
Old 12-22-2005, 02:23 PM   #9
Old Yeller 1970
DON'T TREAD ON ME
On my truck, I jacked up the rear end and crawled under it, in front of the rear axle. Then looking to my left about 10" from the pumpkin it was stamped on the axle facing straight toward the front of the truck.
There's no guarantee all of them were done that way but on mine it was right where the mechanic told me to look.
Old Yeller
Old 01-04-2006, 02:01 AM   #10
70' Chevy
Thanks for the codes they helped! Had trouble in locating it but at last I found it stamped on top of the pumpkin on the drive shaft side. Palf, you & 72 Longhorn may want to check there. The code on it was a THU 4:10 version.
