Old 12-20-2005, 07:29 AM   #1
dave3156
Need rearend advice
I just heard from the repair shop that the rearend on my 1970 Stepside has gone out. I thought this might be a good time to change gears. It has a 350 engine with some performance upgrades (Performer rpm manifold, Edelbrock #1407 carb, headers, dual 3" exhaust), and a Saginaw 3 speed transmission. I'm not sure what gears were in the truck. The mechanic thought they were 3:23 gears. He pulled the hub and counted the gears. Does anyone have an idea of what would be the best gears to run. I drive it mostly on weekends and short trips. Gas mileage is not a factor, performance is. I'm considering 3:73 gears. The tire size is 295/55/15. Any advice is welcome. Thanks.
dave3156 is offline   Reply With Quote
Old 12-20-2005, 07:34 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Need rearend advice
I wouldn't ever spend much money to repair a rearend in one of these trucks. A six lug rearend is super easy to find. I have given away 3.73 6 lug rearends before. Everyone swaps to 5 lug, so 6'ers are all the time turning up needing a new home.
BTW, I doubt the 3.23 gears. It should be either 3.73 or 3.08.
If you're after performance and not mileage, definitely go 3.73.
Old 12-20-2005, 08:47 AM   #3
355
355's Avatar
I agree with TX it is a 3.07 or a 3.73. If you install a 3.73 and had a 3.07 it will feel like you just added 50# of torque, but your top end will be limited by engine rpm. If you have a modified cam you need to match your rearend ratio, and tire size to when your cam is coming in. If gas milage is no problem I would find an Eaton LSD and 3.73 gears. Now is the time to go 5 lug and upgrade to front disc. My to cents.
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 12-20-2005, 10:44 AM   #4
dave3156
After further discussion I found out the rearend is a 3:07 ratio. The axle is already five lug, as is the front axle, and I already have disc brakes in the front.
Old 12-20-2005, 11:17 AM   #5
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I'd drop in the 3.73's and put in a limited slip or locker while you are at it.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 12-20-2005, 11:25 AM   #6
67chevemall
67chevemall's Avatar
Your in the loop! Go for the posi! 3:73 or 4:11
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 12-20-2005, 11:53 AM   #7
355
355's Avatar
If you go 4.11 you will probably have to go to the next size carrier due to gear offset. Your highway speed will be crap and you will not be able to hear your radio due to engine rpms, but that all depends on what is pulling your trigger.
