12-21-2005, 09:56 AM | #1 |
Body Mount Bushings
A while ago (August-September) somebody posted the summit racing part number for a complete suburban poly body mount bushing set. If somebody could post that part number, that'd be great.
Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside) 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
12-21-2005, 10:06 PM | #2 |
Re: Body Mount Bushings
Here you go:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-21-2005, 11:22 PM | #3 |
........so how hard/easy is it to replace those bushings with the cab on frame?
How do you do it?
-----the fleet----- '72 K20 Chevy Suburban '72 Datsun 510 (vintage racer) '89 Honda Civic Si HB '89 Honda Civic Dx HB '08 Honda Element EX-P '78 Honda Express (50cc. pit-ped) pix here |
12-22-2005, 08:52 AM | #4 |
Instructions from EST:
Spray all nuts to be removed with your favorite rust buster. Tighten all bolts to factory specs. Remove rear bumper. Remove top mounting brackets for radiator. Move radiator slightly to the side to remove bolt for position #1. Loosen all positions. Now remove the bolts on ONE SIDE ONLY ! When jacking the body, use a long enough 2x4 or 4x4 for maximum support. Never put the jack directly on body panels. Remove old body mounts, now install new Energy Suspension body mounts and associated parts using the below diagram as a guide. When disassembling, take special note of the quantity and positions of any shims that may have been inserted for body alignment. NOTE: When installing Position #1, be sure to remove one of the OEM washers between the body and frame and place it under the frame as shown below. Here another post that might help: http://67-72chevytrucks.com/vboard/s...73#post1474173
12-22-2005, 09:32 AM | #5 |
Cool, Thanks!
