12-21-2005, 03:53 PM | #1 |
Adding A/C
Wanting feedback from people who've added A/C to their truck. My 81 Sierra Classic came from the factory with cruise as the only option. I added a tilt column years ago, but now I want cold air. I was planning on scrounging brackets, ducts, vents, controls and everything from a wreck and buying parts store condenser and compressor. That way everything looked like the General did it.
But now I'm wondering if an aftermarket system wouldn't be better so there is no doghouse under the hood for the evaporator. Is there an aftermarket kit that uses the factory dash controls? That is one thing I won't deviate from. It's got to use the factory dash controls.
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
12-21-2005, 03:57 PM | #2 |
Re: Adding A/C
Look at vintage air. They have a number of kits avaliable.
70 C/10 SWB Go ahead chance it........Columbus did!!! Steve (Chitlin) Bacon My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/ |
12-21-2005, 04:09 PM | #3 |
Re: Adding A/C
Aftermarket is prolly the easiest to retrofit A/C. The firewall openings are different between a factory A/C cab and a non A/C cab.
12-21-2005, 05:18 PM | #4 | |
Insert Witty Text Here
Re: Adding A/C
Slonaker |
12-21-2005, 06:26 PM | #5 | |
Re: Adding A/C
I was just at the Vintage Air site and it shows the system using the original controls. I'll check that out more.
12-22-2005, 03:20 AM | #6 |
LED King
Re: Adding A/C
I'll tell you, Vintage air will probably be the most cost effective way to add a/c. Just to get my a/c to r134a was $300+ (including compressor) and that is if you have all the equiptment (vacuum pump, gauges, & lines).
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
12-22-2005, 11:14 AM | #7 |
Re: Adding A/C
A friend of mine used to work at Vintage Air. he says the kit is of good quality.
Slonaker |
12-22-2005, 11:53 AM | #8 |
Re: Adding A/C
When I got my truck it had an aftermarket kit in it.
It worked well, but I had problems and didn't like the design. I was from some company in Texas. I ripped it all out and have no A/C in Phoenix, its hot. I vote factory a/c!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
