Old 12-21-2005, 09:05 PM   #1
1967k30
1967k30's Avatar
Need help,No power
I have a 67' k10 with a 350 in it and it's been mainly sitting for the last year.Been torn up.It was started off and on but not driven very far. I had the carb rebuilt about 14mo ago and it ran really good then.I also put new plugs in it.It has fresh fuel in it now. It starts prety good, and runs decent in 1st and 2nd,but 3rd and 4th have no go.Tops out at arount 30-40mph .Doens't seen like I'm getting rpm's either. Engin was supposedly rebuilt within the last 10k but who know hpw many years ago that was.I have owned it for 2yr and it ran good when I bought it. Any help would be appreciated.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 12-21-2005, 09:08 PM   #2
truckdude239
truckdude239's Avatar
Re: Need help,No power
sounds like an clutch
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-21-2005, 09:11 PM   #3
wink_tim
wink_tim's Avatar
My first thought is the fuel filter.
67 SWB
wink_tim is offline   Reply With Quote
Old 12-21-2005, 09:18 PM   #4
rkarr
rkarr's Avatar
How long has it been sitting before you started it this time?
Did you drain the float bowl(s) and flush with fresh gas?
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 12-21-2005, 09:27 PM   #5
1967k30
1967k30's Avatar
I wondered about the clutch.If that's all it is I'd be very happy because I'm installing my 5spd very soon and will have a new clutch installed anyway.
I will check the fuel filter.
It's only been sitting a couple weeks but I never did more than drive it around the yard and back into my shop. Yesterday I took it out for a mile of so and noticed it having no power.Today I took it back out and the same results.I adjusted the timing a little but that didn't change anything.
Old 12-21-2005, 09:51 PM   #6
davidh
davidh's Avatar
does it act like it' starving for fuel? Or does it rev up and just not do much?(go-go)
davidh is offline   Reply With Quote
Old 12-21-2005, 09:55 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you say it doesn't seem to rev.... then it won't be the clutch.
Old 12-21-2005, 09:57 PM   #8
1967k30
1967k30's Avatar
It's not starving for fuel.If anything it's getting a little too much. It seems to rev to an extent,in neutral you can rev it up,It seems to just kinda die out about 35mph or so.Kinda guessing on mph because speedo is disconected.
Old 12-21-2005, 10:50 PM   #9
skeeter288
could you possibly have a vacuum leak?not letting distributor advance?
skeeter288 is offline   Reply With Quote
Old 12-21-2005, 11:47 PM   #10
northcountry67
northcountry67's Avatar
It sounds to me more like a spark advance problem. Remove the dizzy cap, disconnect the vacuum line to the dizzy and put suction to it with your mouth. Hold the suction and see if the advance holds or moves. With vacuum, the spark should advance and hold as long as there is vacuum and should return to normal when you release the vacuum. Check your vacuum lines first. If the advance slowly moves with constant vacuum, you have a bad advance.
northcountry67 is offline   Reply With Quote
Old 12-22-2005, 10:57 AM   #11
wibilly
wibilly's Avatar
i used to have a 64 with a 283 ran great around the yard but on the road nothing in 3rd and 4th it was a badly worn cam
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-22-2005, 07:40 PM   #12
1967k30
1967k30's Avatar
Thanks for all the idea's.I'm going to try to get it looked at soon.I was figuring it was probably in the distributer but I don't have any experience working on them.
Old 12-22-2005, 09:19 PM   #13
truckdude239
points or hei if its points i'd pull it out and put in an hei unit
David fuller
2000 Tahoe 5.3l 378
Old 12-22-2005, 09:47 PM   #14
cdowns
cdowns's Avatar
sounds like you need what is commonally refered to as a "TUNE-UP"
Old 12-24-2005, 11:39 PM   #15
1967k30
1967k30's Avatar
It is HEI. I changed the coil and the cap for starters.Now the truck won't start It looks like I'll have to take it to a mechanic who knows more about electronics than I do.
Old 12-25-2005, 12:46 AM   #16
davidh
davidh's Avatar
See if the truck is getting spark. Pull sp plug wire and put it towards the frame. Have someone crank the motor and see if there is a spark.
Old 12-25-2005, 12:30 PM   #17
mjrmn
'67 K10 Work In Process
mjrmn's Avatar
A buddy of mine has the same problem with a Torino he stored for the winter months and only started occasionally.
His problem was MICE. They had built a nest in the tailpipe right up next to the muffler. Started and idled fine but the first time he took it out on the road it had NO power.
He brought it back into the yard and proceeded to rev the bejeepers out of it,
and all at once there was a big POP and out flies this big pile of yarn and straw and crap all over the lawn!
I laughed so hard I thought I was gonna puke!
The whole time he is running around trying to pick this junk off the lawn I am giving him crap about how his furd is now down about half his horsepower because he just killed off the most powerful parts of the vehicle!!
Point of the story is don't overlook the possibility of an exhaust restriction.
Merry Christmas
Mike
mjrmn is offline   Reply With Quote
Old 12-25-2005, 03:30 PM   #18
1967k30
1967k30's Avatar
I have seen that exhaust restriction before.It was very funny when all the dead mice and their nest came out.
I finally got it fixed When I changed the coil and cap I had hooked that single wire up wrong.The one that plugs into the side of the cap. I got to messing around with it and thought I'd switch it around.Now it runs awsome,except that it idles way to fast.I think that is timing adjustment. Thanks again for the help.
Old 12-25-2005, 03:58 PM   #19
truckdude239
gald you got it fixed wtg
David fuller
2000 Tahoe 5.3l 378
Old 12-27-2005, 02:54 AM   #20
rkarr
rkarr's Avatar
Merry Christmas
Mike
Hehe!!!!
That's funny!!!
However, back to the point... I'm thinking he has some bad fuel in the carb..... did ya try blowin' the rodents outta' it?
1969 Fleetside:
