12-21-2005, 09:05 PM | #1 |
TOTY 2006
is this a dana 44 and is it hard to get calipers for it?
Hi All,
Found this axle, guy thinks its 4:11, pretty cheap, but it does not have calipers. claims it is from a 3/4 ton 86 truck, this is a dana 44 right? Is it hard to get calipers for this? Can 1/2ton calipers be used? He is asking $100.00 for the front axle.... |
12-21-2005, 09:13 PM | #2 |
Re: is this a dana 44 and is it hard to get calipers for it?
Its not a dana 44. its a 10 bolt. I think 1/2 calipers will work on a 3/4 but im not sure. they shouldnt be expensive regardless. thats a fair price too.
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
12-21-2005, 11:57 PM | #3 |
Windy Corner of a Dirty Street
Yes, ½ ton calipers and ¾ ton Dana 44 or Corp 10 bolt brake calipers are the same. When I swapped my 6 lug ½ ton front brake rotors to 8 lug to match my swapped in 14 bolt FF rear axle, all I had to do was swap rotors and backing plates. The caliper and brake pads were the same.
$100 is a good price. Better score that 14 bolt full floater as well. I wonder how much he wants for that.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
12-22-2005, 12:39 AM | #4 |
TOTY 2006
The rear is already sold....
So, the newer 10 bolt front axle is a good axle for normal driving/towing/fireroad driving?/ I don't plan on rock crawling... Thanks for the info... |
12-22-2005, 01:00 AM | #5 |
Too bad about the 14 bolt rear. I have always heard the front Dana 44 and Corp 10 bolt were about equal strength. Sure, we would all love to have a Dana 60 up front but they are getting hard to find and cost a mint. For what you are planning to use it for I am sure you will be fine.
I just ordered a 4:56 gear set, rear Detroit locker and front Detroit Truetrac for mine. I guess I will see how long my front Dana 44 lives once it is geared and limited slipped behind big block power. The truck doesn’t see insane rock crawling or skying over dunes but does see it’s fare share of beatings on trail rides and snow runs. In a perfect world, all of us would have a geared and locked front Dana 60 in our Christmas stockings this year.....but we know that isn't going to happen.
12-22-2005, 05:51 PM | #6 |
TOTY 2006
Well, picked up that axle today, guy also gave me the front sway bar, shocks, springs and u-bolts... Even loaded it into the truck for me....
Slowly getting ready for that bigblock swap/powersteering conversion/power brake conversion for the 67 burb... |
12-22-2005, 06:14 PM | #7 |
Sounds like a fun project John.
I like your Sub….that is a nice ebay find. I might even have a full gauge 1968 GMC instrument cluster laying around with an aftermarket tach mounted tastefully in it. The bezel is even factory red and would match your truck nicely. Come to think of it…..I may have the matching glovebox door too. If I can find them I will shot you a picture and see if you are interested in it.
12-22-2005, 11:45 PM | #8 |
Remanufactured brake calipers are insanely cheap for the 10 bolt & 44's. My last set cost me a whopping $15 a piece. I just about crapped my self when the parts guy qouted the price.
12-23-2005, 07:36 AM | #9 |
user # 2756
I bought a pair of loaded calipers from autozone for $54. Include the calipers/pads and the bolts for holding them on, plus a few other misc parts. (3/4 ton dana44)
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
12-23-2005, 12:15 PM | #10 |
ahh no. must use 79 + calipers if you want your brake line to bolt up. banjo bolt id larger on the oler models. any caliper 1/2 or 3/4 for 1986 will work fine
12-23-2005, 02:33 PM | #11 |
Good point gn4u2c…..
I bet in John’s case he will be adding new brake hoses when he does this axle swap into his 67 burb anyway. The drum brake hoses would not have worked with any year of disk brake caliper regardless. As long as the brake hoses match the year of the calipers there should be no problemo.
12-24-2005, 02:13 PM | #12 |
TOTY 2006
Good info gn4u2c and DirtyLarry!!!
Thanks!! |
