Old 12-22-2005, 03:04 AM   #1
71jimmy
71jimmy's Avatar
Hardtop storage
I know this has been discussed before, but for the life of me I can't find any of the info using the search function on this board.
When removing and storing the hardtop, GM recommends using two pieces of wood front and back to keep the hardtop somewhat rigid while off the vehicle. My FACTORY manual says to have two pieces 72" long and to drill 3/8" holes 63" apart. NOW, I measured across my bedsides, from center of top screw hole to center on the other side, and it measures like 67 and 1/4".
Is my manual wrong? Or is 63" correct, so that the sides of the top are pulled in a little? What have you guys done?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 12-22-2005, 08:49 AM   #2
Joe67
67 is sold
Re: Hardtop storage
Do any of you guys store them like many Jeep Wrangler guys? Use a pulley system and store it above the truck in the garage/shop?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 12-22-2005, 10:45 AM   #3
pierce
pierce's Avatar
Re: Hardtop storage
I use 2 2x4's with eyehooks on each side. 1 2x4 goes behind the front seats where the top bolts to the rails and the other across the back. I did bolt the top to the wood but don't remember the measurements, lately I just let the top sit on the wood without bolting it and hoist it to the ceiling. I do each side a little at a time till it reaches the ceiling.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 12-22-2005, 12:58 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Hardtop storage
A little pricey, JMHO, but I am going to get 2 of these for my tops
(* The 4 point #7806 will handle 200 lbs., might get away with the
#7803 on the single wall top, it's rated for 145 lbs. not really sure)
Featured on Discovery Channel - http://www.hoister.com/selection.php
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-28-2005, 06:06 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Hardtop storage
here's what I did.
Click HERE
made this
and raised it to the roof with this
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-29-2005, 03:11 AM   #6
71jimmy
71jimmy's Avatar
Re: Hardtop storage
Thanks for the replies everyone. I finally found the answer. The FACTORY manual is WRONG specifying 63". Imagine that!!! 67 1/4 seems to be correct. Just wanted to make sure there wasn't anything wrong with my tub since the hardtop has been off for so long.
BobbyK that's a killer setup.
