Old 12-22-2005, 03:11 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need cab squared...
For those of you who have taken cabs off and on what is the best to use for reference when you are lineing the cab back up to be square... Any help would be great....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-22-2005, 03:31 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Need cab squared...
I try to even up the distance from the bottom edge (lip)of the rocker side to side, in both front & rear of the cab to start with. when you start hanging front tin, the hood/fenders will tell the story pretty well on alignment. You may need to play with the pcs a little to straighten em up, but its not too bad. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-22-2005, 03:39 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Thanks crazy I cannot wait to get this truck back together!!!!!
MEMBER #6377
Project "7DEUCE"
Old 12-22-2005, 05:31 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Thanks Crazy, I'll be putting my cab on soon too! Thought it was going to be tomorrow, but found out I have to go in to work.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 12-22-2005, 05:35 PM   #5
crazy longhorn
Hang in & hang on! The resto stuff goes d@mn slow...... the end results will be worth the effort tho..... L
Old 12-22-2005, 07:12 PM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Take some notes on the height of the cab from the mounts in each corner. It is easy to torque them down unevenly. One end has the big square washer that, it left out, will tilt the cab and throw off the front fender gap. Watch the core support mounts too since they are another big source of front fender gaps! This is the part of assembly that I actually really enjoy...adjusting the front sheet metal and doors! I know...I'm sick!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 12-22-2005, 09:40 PM   #7
Bob Moore
Stllookin - When it's time to do mine, I'll give you a call.
Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-22-2005, 09:52 PM   #8
cduster
stllookn- Where does this big square washer you mention go?
I am not recalling it, and might could use it.
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 12-23-2005, 09:44 PM   #9
Brad
Brad's Avatar
I don't recall a big square washer when I took my cab off!?!
Yep, I'll give you a call too!
Old 12-23-2005, 10:24 PM   #10
Gordo
I would suggest assembling the cab mounts and radiator support mounts but don't tighten all the mount bolts down until the nose including the front bumper is installed. You will see why when you get there.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 12-23-2005, 11:38 PM   #11
Green Machine
Green Machine's Avatar
The square washers are for the front cab mounts, my last new set came with 2 for each front cab mount (4 total), but they are optional, the mount will work fine without it. They may be needed to get your fender/door gap right.
Some trial and error will likely be needed to shim everything square.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 12-23-2005, 11:51 PM   #12
409biscayne
409biscayne's Avatar
Bob
Ditto . I see a trip to Kent in my future .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 12-24-2005, 03:44 AM   #13
stllookn
stllookn's Avatar
cduster, Mudder is right...but mine had only one on each side. I left them out and had to replace them when I adjusted my front fenders and clip. Trial and error. Bob...come on up...I will be glad to help. I just love getting those doors so they close with a nice click!
Old 12-24-2005, 11:21 AM   #14
Rokcrln
Rokcrln's Avatar
This is the part I am at right now as well but in a lot more trouble then you guys. I started my 71 6 yrs ago and since then I did a 2" body drop, sectioned 6" out of the bed floor and cut the frame in 8 spots so everything would lay just how I wanted it. So my next step is to fullu assemble the body, shim as needed and then re-make or adjust all my mounts as needed. It will be alot of work but well worth it when completed.
Kevin
Rokcrln is offline   Reply With Quote
Old 12-24-2005, 01:55 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
Heres a pic of the square washers...
MEMBER #6377
Project "7DEUCE"
Old 12-24-2005, 02:13 PM   #16
stllookn
stllookn's Avatar
Rokcrln...we've seen your "art work"...you get no sympathy from us...LOL! Can't wait to see the progress...it is an inspiration to the rest of us metal "butchers"!
