12-23-2005, 02:59 PM | #1 |
Big-Time PROB
rotors are worping on my one ton.
What all can cause this problem?
TRUCKS & Autos that run: 1972 GMC Sierra Grande 3/4ton LWB 4x4 1972 Chevrollet K/5 with a 6"Lift, 462 heads "money pit" 1988 K3500 Crew "Big Red" 4x4 PARTS OR PROJECT TRUCKS: PARTS for sale or trade: WANT : 1972 parts blazer/Jimmy parts truck 1967-72 Parts Chevy/GMC Truck NEED stainless hubcap for 3/4ton GMC |
12-23-2005, 03:01 PM | #2 |
Gone Fishing
Re: Big-Time PROB
heat can cuase it riding the brakes driving under heavy braking condidtions when it's raining sticky calipers etc
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 Last edited by jsbgump; 12-23-2005 at 03:01 PM. |
12-23-2005, 03:10 PM | #3 |
Re: Big-Time PROB
It is a Bendix calipers.
not riding the brakes, I think i do have heat problems. When it is cold outside,it does not have much problems If we are pulling it does not matter.
12-23-2005, 03:26 PM | #4 |
Gone Fishing
Re: Big-Time PROB
what kind of pads are you runnin?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
12-23-2005, 03:45 PM | #5 |
Re: Big-Time PROB
Matalic
12-23-2005, 03:46 PM | #6 |
Gone Fishing
Re: Big-Time PROB
how long ago was the brake job done?
12-23-2005, 03:53 PM | #7 |
Re: Big-Time PROB
If the pedal is not coming back all the way, it will hold the brakes on a little. The pedal has to be back all the way for the ports in the MC to open for fluild to return. Sometimes the spring in the MC can weaken and the weight of the pedal will hold the brakes on some.
If your calipers are all corroded and gungy they won't slide freely, take the pads out and put them back on with the pins and try moving then back and forth, it should be real easy. Lubricate the bushings with high temp grease and clean the caliper and spindle surfaces that come in contact with emery paper. Also, problems in the combo/prop valve can cause this. Hope these suggestions help, It could be a number of things, I would start with just checking that everthing moves freely first.
71 GMC 3500 Longhorn 454 72 GMC 2500 Sierra 350 69 C20 Longbox fleetside 305 68 C10 Shortbox Stepside 250 94 Chevrolet K1500 Cheyenne 350 88 GMC K1500 |
12-23-2005, 04:13 PM | #8 |
Re: Big-Time PROB
I have working on it for months.
Chevy house has looked at (said it was to old for them) part house ( could not get a porportional valve,if it was the prob.) Been to other shops too. What about midas?
12-23-2005, 05:08 PM | #9 |
yeeha
Re: Big-Time PROB
Improper torque and tightening pattern on the lug nuts has also been known to cause this. NEVER use an impact to tighten them down. Try to uses a torque wrench to do this so that you know all the nuts are tightened evenly all the way around….. the unevenness can cause worping. Always try to tighten in three stages, 33% of total torque on all the nuts then 66% of torque on all the nuts and then do your final torque 100% of what the torque should be on the nuts. If you do this and always tighten the nut across then hub your rotors will only worpe from heat … and that’s a whole other story!
1969 GMC 910 97% rust free 2002 olds Alero 1986 New Yorker 4dr ... the new DD...My POS car... dude its got a turbo!!! Don't drink and drive, you might spill something!!! Daryl Kuchmak |
12-23-2005, 06:28 PM | #10 |
Watch out for your cornhole !
Re: Big-Time PROB
Definitely improper torquing of the lug nuts.
12-23-2005, 07:05 PM | #11 |
Crew Cut
Re: Big-Time PROB
one more thing that gets over looked a lot is the brake hose. the inside of the hose will seprate. fluid will pass thru when you apply brakes but when you let off,the hose will suck together and not let the pressure off the calipers. i have seen this a lot on these trucks.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
12-23-2005, 07:51 PM | #12 |
20' Daredevil (Ret)
Re: Big-Time PROB
More than you ever wanted to know about disc brake problems... http://www.stoptech.com/tech_info/wp...rakedisk.shtml
12-24-2005, 12:16 AM | #13 |
Re: Big-Time PROB
Many thanks guys!!!!!
