computer illiterate
well i took my 72 2wd blazer to the scrap yard today
gotcha!
![]() ![]() ![]() ![]() ![]() ![]() ![]() thanks keith
72 2wd blazer 72 swb 4x4 |
computer illiterate
Re: well i took my 72 2wd blazer to the scrap yard today
i found a griffin at summit made for a 67-72 part number gri6567arbax for 469.00 does anyone know of any others?
Most of the aluminum after market radiators I have seen come with the NASCAR 4 fins per inch meaning they leave a BIG air gap between fins so when your going 220 MPH the air dont blow the core out, myself I use the high efficiency brass core radiators that have about 15 fins per inch and transfer MORE heat at 0 to 70 MPH than the fancy smancy "aluminum racing radiators" do, a good friend of mine spent about 1000 BUX trying to cool his blown BB 57 Chevy but once he went to the 4 core brass radiator all his cooling problems went away, think he got 200 bux for his $750.00 aluminum radiator, the aluminum radiator would have probably been ok for a normally aspirated SB engine.
67-72 parts collector,…
![]() Join Date: Nov 2002
I would run a "nice" copper/brass radiator if I could find a supplier that handled a "USA made" radiator. I think I'm going to run an aluminum Griffin or BeCool brand in my '71 project truck. I was pretty disappointed in the 4-core I put in my blazer. It was "suppose" to be a Modine from www.radiators.com,... BUT came in as a import look a like. Poor fit and finish. I installed it because I was in a jam. But that won't happen again.
my bud runs nothing but GRIFFINS in his BB novas (500cid+) never had a problem cruising town etc. (slow speeds)
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I ran a be cool in my v-8 powered yota loved that thing damn truck was alwasy cool...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Mar 2001
check out www.usradiator.com, you might be surprised what you can find.
Aluminum rads are excellent for racers, but you may only get a couple of years out of them in a driver (due to the expansion/contraction and stress between the fins and the tanks).
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
#8 | |
Cool thanks for the link, its nice to see a vendor that shows their math and does not rely on customer hype to prove a point. "We've learned, for example, that core design has more bearing on temperature drop than material (copper- brass verses aluminum). We've also learned that 2 rows of 1-1/4" aluminum tubes had only a 3-degree advantage over 4-rows of 1/2" brass tubes at 65 m.p.h and a 2-degree disadvantage at idle. Given the added core thickness of the aluminum radiator we had expected a greater temperature drop...but, it wasn't there." "Our test of similar core designs proves conclusively that aluminum radiators offer no real temperature drop advantage over copper and brass. On the other hand, aluminum radiators weigh about 2/3rds as much as copper and brass units and if your racing, that 9 to 12 pound difference could be real important." Thanks again. |
Ron Davis makes sweet radiators he is here in AZhttp://www.rondavisradiators.com
Maybe we could get a scrap yard to come and get the blazer.
That should be considered a disgrace to even joke about....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
computer illiterate
he he he i figured someone would jump on that. as for brass to aluminum i think ther is a major difference as i had a 3row brass radiator in my v8 s10 and it always ran hot so i went to a 2 row alluminum and it never got over 190 ever so im deffinately going alluminum i just dont know which one yet.
