12-23-2005, 11:16 PM | #1 |
Fender alignment
I have a '72 GMC 4x4 I have been putting a lot of work into the last couple of years. The truck was my wife's grandfathers and needed help. I am finally getting down to body work and I would like to make this my daily driver. My question is, how do you align the hood, fender and doors? Also I am having an issue with the doors being so far out of adjustment you have to slam the doors for them to shut and you have to lock them from the outside.
I am new to this forum and I have been enjoying reading past posts and I knew I had found a vast resource of info for my hobby. Thanks in advance. |
12-23-2005, 11:57 PM | #2 | |
Re: Fender alignment
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
12-24-2005, 12:00 AM | #3 |
10/30/19
Welcome to the board.All my trucks have to be lock from the outside with the key.As far as aligning your doors,fenders and hood,I start with the doors.The key is to do the adjusting little bit at a time.Get your door real close to where you want it to be and loosen up 2 bolts from the top hinge and 2 from the bottom,keeping 1 bolt on the top hinge and botton hinge tight until you are ready to adjust them.(I work on the hinges that are attached to the a pillar).Then slowly loosen the other 2 bolts moving the hinges forward or back and up or down,what ever is needed.Next the fenders,again small increments are what is best.The hood is the same principal,Loosen 1 bolt on the hood side of the hinge leaving the other tight.I will try to work 1 side at a time.There is better explanation on how to do these adjustments in the faq section I think.Good luck and keep us posted on how things are going.I am sure there will be others who will speak up.
Fight the good fight, finish the race, keep the faith Last edited by kingsolver72; 12-24-2005 at 12:13 AM. |
12-24-2005, 12:46 AM | #4 |
schendel
Sorry I can't help, but wanted to say welcome from Texas. And yes there is a large amount of knowledge to be had here, all you have to do is ask.
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES 's 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
12-24-2005, 01:51 AM | #5 |
10/30/19
schendel,go to the "faq submissions" page 5,under the heading "Martinsrs basics of body panel alignment" is a very exhaustive write up on just what you are asking.
Fight the good fight, finish the race, keep the faith Last edited by kingsolver72; 12-24-2005 at 02:08 AM. |
12-24-2005, 03:38 AM | #6 |
Saving 1 truck at a time!
Welcome from Seattle, WA! Bring it over...I will adjust them for you...it is hard to explain. The hinges adust up and down and in and out. The latch at the rear of the door will adjust in three planes! I start at the top rear of the door and make sure the gaps at the top, rear of the door and bottom are correct first. The gap between the front fender and door can be handled later when you adjust the front clip.
If you only need to adjust the door in and out you can do this with the door latch plate and the bolts that hold the door to the hinge. If you have to align the door in the opening (adjust the gaps) you will need to remove the front front fenders to gain access to the hinge bolts for doing this adjustment. Before you loosen any bolts, if this is your first try at this, mark around all the hinges and the door latch plate with a pencil or scribe so that you know exactly where the door was when you started. This will help you if you only need to make a couple of minor adjustments. After you have done a couple of these you can forget about marking it...since it will become second nature. Good Luck...keep asking questions...it is the only way to learn.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
12-24-2005, 08:07 AM | #7 |
Amongst the other references, alignment of body panels is much more patience than anything else. Don't try to fix them all at once. I start with the doors, then work the fenders and hood into place. But you'll be back to the doors again in the process. Remember little baby tweaks. You feel yourself getting aggravated, walk away, take a breather.
Welcome to the wonderful world of the greatest old trucks.
12-24-2005, 10:41 AM | #8 |
Thank you all for your advice. I will give it a shot over the Christmas break. The alignment became worse when I replaced the original cab mount bushings and I suppose it's sitting a little different now.
1972 GMC Sierra 1/2 ton 4x4 Painless wiring harness Dual Optima New Springs and shocks New S/S brake lines from Inline Tube 33x16.5x12 on 16.5 Rock Crawlers |
12-24-2005, 11:05 AM | #9 |
If you haven't also replace your core support bushings. Old copre/new cab bushings make alignment even more fun.
12-24-2005, 02:23 PM | #10 |
If your doors are bare, they will sag down at the back once you put in all the glass, regulators, and other parts. Don't know how to resolve that one, I might have to weigh everything and come up with some kind of weight to put in there during adjustment.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
12-24-2005, 03:06 PM | #11 |
Designated A-hole!
Here is the best way to get around the FAQ Submissions page.
http://67-72chevytrucks.com/vboard/s...d.php?t=157669 It has links to everything we have. You want to check out Martinsr's basics thread on panel alignment. Then just for the heck of it check out the rest of his articles, they're great reading.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-24-2005, 03:07 PM | #12 |
Designated A-hole!
BTW Welcome to the board from South Mississippi.
