Old 12-23-2005, 11:58 PM   #1
chevythunder33
chevythunder33's Avatar
Question rust bullit
Hello guys any of you know anything about rust bullit if it's as good as they say it is or would you recomend por 15 for the frame?
chevythunder33 is offline   Reply With Quote
Old 12-24-2005, 12:21 PM   #2
fiream
Re: rust bullit
It seems to be fairly well thought of on some of the painting boards I frequent. I was going to POR-15 the frame of my Suburban but went with Zero-Rust instead as it's supposed to be more user friendly and just as good. A LOT cheaper too. I also picked up an Industrial Coating called MasterSeries that folks on an MG restoration board were raving about. If I'd known about it earlier i would have bought a gallon of it instead of the Zero-Rust. Anything that can withstand the effects of weathering/rust on a bridge will probably hold up pretty well on a vehicle. I used to use Briner Industrial Coatings until Plasite bought the plant out down here and then shut it down. I have yet to find anything that compares to it. Almost every refinery and offshore rig down here was painted with Briner Paint. They had one paint so tough that it had to be ground completely away before metal could be cut with a torch. I hope this MasterSeries proves to be as good as the Briner at least as far as sealing out moisture.
http://www.masterseriesct.com/default.php
http://www.zerorustusa.com/
Fiream
fiream is offline   Reply With Quote
