12-23-2005, 11:59 PM | #1 |
1ton lca question!
what wears on the one ton lca? is it the nut or the shaft? or are they designed to not wear, and never get replaced?
12-26-2005, 11:22 AM | #2 |
Fabricate till you "puke"
Re: 1ton lca question!
Both pcs wear, it just depends on how much wear as to replacement parts used. I have gotten lucky enough to replace bushings only & tighten up an old truck for a while. If you have lots of slop in the arms, you would be best to change shafts & bushings tho.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-26-2005, 04:24 PM | #3 | |
Happy to be here
