Old 12-24-2005, 02:16 AM   #1
hilljob26
hilljob26's Avatar
windsheild washer wont squirt
alright yall,i need some help,i fially got the girl going again after a bad motor,anyway,i was putting in my washer bottle,and started to begin to make sure it worked,so that io could aim my nozzles where i wanted them,but nothing is coming out.this has sat for at least 3 years,as far as i know,there is 3 hoses coming off of the pump,i am assuming that the long one on the top is the water in and the 2 other are water out,anybody have any ideas
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 12-24-2005, 10:03 AM   #2
byrd
Union Electrician
byrd's Avatar
Re: windsheild washer wont squirt
That is correct, and you can still buy them from GM, the washer pump that is. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-24-2005, 12:08 PM   #3
hilljob26
hilljob26's Avatar
can you take the washer pump off seperatly from the whole wiper setup
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-24-2005, 12:15 PM   #4
hilljob26
hilljob26's Avatar
and if that is the case,yall wouldnt happen to have an extra laying around
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-24-2005, 12:15 PM   #5
byrd
Union Electrician
byrd's Avatar
I think so, it looks like there is a screw point at the inlet side(small metal tab above the inlet), and then another screw piont and metal mounting tab at the opposite end of the pump.
Zip:40272
Old 12-24-2005, 12:17 PM   #6
byrd
Union Electrician
byrd's Avatar
I have a brand new GM one that I paid about $45 or 50 shipped from gmpartsdirect.com part# 4919332
Zip:40272
Old 12-24-2005, 12:38 PM   #7
hilljob26
hilljob26's Avatar
hay randy,you dont by chance have a pic do ya
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-24-2005, 01:18 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I need to replace mine too but have not found time to stand on my head to do it, I have the washer bought it many years ago...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-25-2005, 10:43 AM   #9
byrd
Union Electrician
byrd's Avatar
Mike, I will email you a picture of iot tonight or tomorrow. I didn't see you asked about a pic until now. Randy
Zip:40272
Old 12-25-2005, 11:43 AM   #10
Anita
I have the same problem--but Advance AP offers a rebuild kit. Would that 'fix' the washer pump? Just asking vs. $50 for a new one.
Anita is offline   Reply With Quote
Old 12-25-2005, 11:57 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Anita, welcome tot he board.
An easier and cheaper way is a unerversal replacement inline pump. You can get one at wall world or any parts store, and normally for right around 10 bucks. These give a more positive stream, and much more power too.
Personally, I have only seen one of the original style pump actually work.
Old 12-25-2005, 11:58 AM   #12
gator2511
gator2511's Avatar
I bought my new pump assembly at Chevy Duty for $27.95.
gator2511 is offline   Reply With Quote
Old 12-25-2005, 01:10 PM   #13
72k5
72k5's Avatar
Unless you're into staying original, I would second Longhorn Man. The new style electric inline pumps just work a lot better. Plus, you get to control how much gets applied, unlike the set wash cycle of the original set up.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 12-25-2005, 06:45 PM   #14
hilljob26
hilljob26's Avatar
anybody have a pic of that,what exactly am i looking for,and where do i find it,i just ordered a replacement pump,but if that is easierr to put in and works better,then i will go get one,ecpecially if i can get it in town
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-25-2005, 09:36 PM   #15
Anita
Hey y'all! Something like http://www.partsamerica.com/ProductD...pe=335&ptset=A?
Old 12-26-2005, 12:37 AM   #16
hilljob26
hilljob26's Avatar
so do you basically just wire that up as your washer and disconnect your washer hoses from the factory washer and plumb them through that,thats pretty cool...mike
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-26-2005, 12:00 PM   #17
farside847
farside847's Avatar
I just replaced mine, seemed easier than trying to rebuild a 30 year old unit. New one swirts just fine!
Oh, I bought it from GMSPauls for about $25 I think...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 12-26-2005, 12:54 PM   #18
shoobear
shoobear's Avatar
ok, i just got a 1970 gmc, and there is only a hose floppin around under the hood. Where did the res and pump mount?
cheers
I will run u over for FREE!!!
2001 F350 6" Lifted Dually
1970 ScoutII with chevy implants
1970 GMC 3/4 LB 4x4 (for sale)
1972 Chevy 3/4 LB 4x4 -project
shoobear is offline   Reply With Quote
Old 12-26-2005, 01:08 PM   #19
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Maybe its not working because you have a cracked/broken hose?
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 12-26-2005, 06:29 PM   #20
hilljob26
hilljob26's Avatar
mine has all new hoses and resivoir,it just is not sucking the fluid up
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-26-2005, 11:37 PM   #21
roger0080
Just buy the pump rebuilt kit. All that is wrong when they don't pump is the rubber valves are shot. $5.88 and some of your time:
NAPA use to stock these. Maybe they still do?
HTH.
-Roger
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
