SWB 4X4 CLUB
Shackle question
I am in need of the shackle assembly for the rear of the front leaf spring on a 68 chevy 4X4. I have enclesed a picture of what I need, It says that these fit 67-72. I was under the impression that the width of the 67-68 leaf springs were different that the 69-72. Also would I be able to get these in a local parts store.
Almost forgot but here is the pic.(I need Everything in the box marked 9) |
Junk/Daily Driver Club
![]() Join Date: Feb 2004
Re: Shackle question
Check with Offroad Design.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. ![]() There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! |
I got mine at a local spring shop. The front springs are the same 67-72 but the rears are different length but the width is the same on the K10. Chris
When i brought home my 69, i discovered that 1 of my front shackles was cracked all the way thru. i had a local shop cut me a replacemtent out of 3/8" steel. That worked great! i have since replaced with the ORD greasable shackle kit that is a little longer than stock... but the bushing should be available at any parts store, and just put in some grade 8 bolts...
