Old 12-24-2005, 01:15 PM   #1
gregbr
Senoir Member
gregbr's Avatar
L.E.D. lights in gauge cluster??
Anybody installed LED's in the instrument panel for the gauges? I found these replacements for the 194 bulbs, they have several styles to choose from. From what I've read elsewhere, it's best to use the bulb assemblies with at least 4 LED's. I'm curious which color to use....white or green. Any ideas??
http://www.superbrightleds.com/1157.htm
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 12-24-2005, 01:32 PM   #2
BowTieMan
BowTieMan's Avatar
Re: L.E.D. lights in gauge cluster??
Hmmm. thats a good idea. Paint the area around the gauges gloss white and add a green bulb and that would be pretty bright. What do you guys think about that?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 12-24-2005, 02:52 PM   #3
byrd
Union Electrician
byrd's Avatar
I have installed and sold several sets of the 4 point LEDS, and they look and work great. I sell them for $5 per bulb in about the same variety of colors as the do. I always paint the inside of the tins white(backing plate, and inner tin) to achieve the best possible reflection of light. If you have a stock black cluster the colored bulbs won't really show up that well, mainly the color is for the white dashes and then you get a huge difference and a very cool effect. Just my .02 Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-24-2005, 02:54 PM   #4
BowTieMan
BowTieMan's Avatar
So what is it on the stock gauges that gives it that green glow?
Old 12-24-2005, 03:16 PM   #5
70c10
67-72 Addict!
70c10's Avatar
The inside of the tin is factory painted a pale green. If you do what Randy said and paint it white it looks alot brighter.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-24-2005, 03:30 PM   #6
BowTieMan
BowTieMan's Avatar
But If I just paint it white will it glow white or will it still have a green glow?
Old 12-24-2005, 03:48 PM   #7
krue
Designated A-hole!
krue's Avatar
It should glow white.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-06-2006, 07:06 AM   #8
gregbr
Senoir Member
gregbr's Avatar
The 4 LED bulbs are a liitle brighter than the original bulbs when installed in the turn signal lights & hi beam indicator. The 6 LED bulbs installed in the open holes appear a little brighter than the stock bulbs, but they don't disperse the light evenly around the gauges, they make bright spots dirrectly in front of the bulb. Might should try the 5 LED bulbs that have 4 LED's around the sides. I left the tins stock green and used green LED's. I also noticed the dimmer switch will NOT dim the LED's, they are either on or off. Both LED bulbs fit the regular sockets and the housing with no problem (no mods), the 6 LED bulbs actually are a little smaller than the 4 LED bulbs....somehow. Greg
Old 01-06-2006, 07:43 AM   #9
byrd
Union Electrician
byrd's Avatar
LED are like flourescent lights, can't dim them. The reason you aren't seeing a big change in lighting is that you left the inside of the tins the factory green(very poor reflection) had you painted the inside white it would have made a huge difference. I try to see if I can get a pic of the LED in the dash one with a white background finish and one with the factory color green. The white also really helps to spread the light out so that the LED light looks more even. My .02 Randy
Zip:40272
Old 01-06-2006, 09:20 AM   #10
67chevemall
67chevemall's Avatar
Any pics? sounds cool!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-10-2006, 04:15 AM   #11
gregbr
Senoir Member
gregbr's Avatar
Thanks Randy, would love to see pics. Greg
Old 01-10-2006, 08:39 AM   #12
70c10
67-72 Addict!
70c10's Avatar
Certain LED's will distribute the light more evenly than others. If you look at the Duranged website for our trucks, the light is cast in an Up and Down pattern. I would try different LED's for the best pattern.
Jim
Old 01-10-2006, 05:56 PM   #13
dinnut
dinnut's Avatar
my friend has the 5 led's in his 96 tahoe... he can dim them all the way till they are out...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-10-2006, 07:06 PM   #14
shaneschevys
Its always something!
shaneschevys's Avatar
this is what mine looks like with blue bulbs and white gauges.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 01-10-2006, 10:22 PM   #15
byrd
Union Electrician
byrd's Avatar
Shane you are the first person who has gotten a good pics of them at night, beside durange. How did you get them to turn out and could you get some better pics? Randy
Zip:40272
Old 01-13-2006, 06:57 PM   #16
70c10
67-72 Addict!
70c10's Avatar
What type of LED bulbs did you use?
Jim
